Rsg magnum or liberty magnum?
Old 10-08-2015 | 08:59 AM
Busted67's Avatar
Default Rsg magnum or liberty magnum?
I've been doing some research on upgraded magnums that
Can handle 850-1000rw horsepower. I've narrowed it down to
Liberty and rsg. Liberty does cf blocker rings, bronze pads
And cryo treating/ polishing to the gears and shafts.
Rsg does carbon bronze blocker rings and different plastic pads
But the replace the gearset with a 9310 alloy set.
Both cost around 4500$ I called tremec to find out what the stock
Alloy is used and they won't tell me.
Car is 1st gen camaro 5.3 with twin 60's 99% street car.
So which one is better for my set up?
Old 10-08-2015 | 03:31 PM
blue99fbody's Avatar
call rpm transmissions Jeremy can get you set up with what you need they are the best in the business to work with
Old 10-08-2015 | 03:45 PM
Busted67's Avatar
Rpm is over priced from what I can see on their website.
Old 10-08-2015 | 04:26 PM
Jeremy@RPMTransmissions's Avatar
Our Level 7 T56 Magnum is $4,795.00. Our prices are comparable to anyone in the industry but you will have a hard time finding a comparable level of customer service that you will get here with us at RPM.
Jeremy
Old 10-08-2015 | 06:52 PM
Busted67's Avatar
I'll give u guys a call tomorrow.
Old 10-09-2015 | 08:10 AM
Sounds good. Just ask for Jeremy when you call in.
I look forward to talking with you.
Old 10-15-2015 | 03:18 PM
axe murderer's Avatar
What did you decide?
Nobody can dispute that in the manual trans drag racing world Liberty's is & has been on top for a long, long time.
Liberty probably has the best price because the can do most everything in house & when they send things out they do it in volume & locally.
A few years ago I took my T56 to Liberty's, sure took their time but I wasn't in a hurry & didn't really push them which probably wouldn't have done any good since there's always a lot of their pros stock transmissions getting done.
Old 10-15-2015 | 03:45 PM
Busted67's Avatar
I think I'm going with rockland standard gear. It's built with a 9310 alloy gearset and all of the shift improveing mods are included with the price. Which is around 4600$. Every body else treats the factory gears with heat treating/cryo.
Old 10-15-2015 | 03:55 PM
Just so you know, Rockland uses stock gearsets too. They are not making a completely new TR6060 gearset and selling it for less than everyone else.
Old 10-15-2015 | 05:32 PM
Busted67's Avatar
So are u saying they don't make the gearset from a different material? Cus I was told by them they use a 9310 alloy instead of the stock so that would lead me to believe it was custom made/machined.
Old 10-15-2015 | 06:40 PM
stevieturbo's Avatar
Do the RSG T56's not use a different gearset ? Maybe that's where the confusion lies ?
When I contacted Tremec ages ago about their F-Body Magnum which never appeared, they said Cryo treating was not recommended on the Magnum gears.
Is there a dog engagement option for the Magnum yet ? RSG site mentions about a possible dog option although think it's for their Tranzilla...but no info.
Old 10-15-2015 | 07:50 PM
SStressin's Avatar
Do not use rockland standard gear. I had a t56 magnum that lasted 3 weeks with 600 miles and grenaded. They have a 1 year warranty and would not warranty it. Personally went to the shop and was om the phone with different people all claiming to be the owner of rsg then i finally got a hold of george who is rsg owner and he is a real dick to say the least. Got my magnum back from them in a crate. The remaining good parts of mine will be going to tick or rpm for a proper t56 magnum with great customer service and a warranty that actually means something. I am not the only one this has happend to. Over on the corvette forum a few people have had problems with their warranties. They accuse you of everything else being the problem
Old 10-15-2015 | 09:57 PM
Busted67's Avatar
Ahh it can never be easy can it. I hate a company that won't stand behind their product. I just wanna buy it once if possible.
Old 10-16-2015 | 03:44 AM
grenaded in what way ?
Old 10-16-2015 | 12:50 PM
gnx7's Avatar
Of note- I'm running a completely stock T56 Magnum (2.66 ratio) making 1000-1200rwhp behind an 88mm turbo 6.2 liter without issues. I don't launch hard nor do I powershift.
9.35@163mph best so far. 1.59 60', 6.268sec/128mph 1/8th
On 14psi it made 1060rwhp/1070rwtq. I've had it up to 22psi in 5th gear without issue. At that powerlevel (not dyno'd) it pulls crazy hard.
The car is a 100% street car that mainly is used for 1/2 mile racing where you need 5th gear. It does nearly 175mph in 4th.
Old 02-08-2016 | 01:01 PM
I need to clear up my previous post. I was wrong about the gearsets that Rockland Standard gear uses in their HD2.66 T56 Magnum transmissions. They are using a 9310 gearset that is produced by Tremec. I was not aware that the Viper TR6060 used 9310 gears. My ignorance got the better of me in this case.
Old 02-08-2016 | 02:09 PM
So it sounds like a Viper 6060 is considerably different to other 6060's or Magnums ?
Old 02-08-2016 | 02:12 PM
It appears that they are significantly better.
Old 02-08-2016 | 02:33 PM
Busted67's Avatar
Can u make a magnum with this gear set? Or just buy a viper 6060?
Old 02-11-2016 | 04:17 AM
gnx7's Avatar
The T56 Magnum is a TR6060.... it just meets the dimensions of the Fbody trans... with a 31 spline output shaft and is 2" longer approx.
If you want the big boy T56 ..... PPG offers a sequential conversion with billet internals... but that's about $20K+. So the question remains.... put 6.5 complete T56 Magnums in your toy box.... or 1 PPG billet sequential BMF.
