Back with old clutch
Old Mar 11, 2018 | 03:30 PM
johnfin's Avatar
Default Back with old clutch
So at 110K miles I put a monster stage 1 clutch in with a tick master cylinder. At 125K and driving in traffic its wearing my leg out and I want to install the old one back in. My intent is to use the original GM pressure plate, monster flywheel and tick master cylinder. Couple of questions:
1. Is this a bad idea
2. Can I mix and match parts or.
3. Will the monster flywheel work with the GM pressure plate
Old Mar 11, 2018 | 05:58 PM
big hammer's Avatar
If you are using a tick 7/8 master, go down to a 3/4 or 11/16. Any 75 series Tilton master will fit the tick block. It will make the clutch much easier to push.
Old Mar 11, 2018 | 06:04 PM
big hammer's Avatar
Also the Tilton masters are like $100
Old Mar 11, 2018 | 07:51 PM
johnfin's Avatar
Default changing master
That master is a mother to change. If it comes out, a stock one will replace it.
Old Mar 11, 2018 | 08:01 PM
big hammer's Avatar
Don’t be a goofy gus. A $100 Tilton will solve your problem
Old Mar 12, 2018 | 06:52 AM
wssix99's Avatar
Save the manuals!
Are you in stop and go traffic every day?
I got used to this over time as my leg got stronger.
Did you take the clutch petal return spring off, per Tick's instructions? If you still have that on, taking it off might make things better and give you something to try before you make any changes. Once the clutch is in, you get a bit of a rest - but that return spring will press against you all the time.
Old Mar 12, 2018 | 06:55 AM
johnfin's Avatar
Default Master cylinder
Show me link for that.
Old Mar 12, 2018 | 07:43 AM
South Bend Clutch's Avatar
The clutch could just be worn out. As a clutch wears, the diaphragm spring raises and you lose mechanical advantage, it becomes heavier to push.
Old Mar 12, 2018 | 09:25 AM
johnfin's Avatar
Its a year old, doubt its worn. I removed the spring. When i put the master and cluth in, the pedal wenr to the floor. Had to adjust the heck out of it to get half pedal release.
Old Mar 12, 2018 | 11:33 AM
johnfin's Avatar
How come you cant buy just the stock clutch disc? The disc mfg's claim the pressure plate is self adjusting, thats why they are sold in kits. Not sure if i believe that.
Old Mar 12, 2018 | 11:59 PM
nmass399's Avatar
He knows what he is talking about, the 7/8 inch bore in my car is very stiff vs the 3/4 inch bore in my dads car. That 3/4 inch tilton is so easy to press that it has to be equivalent to stock on foot pressure. Both of us are running monster level 3’s.
Old Mar 13, 2018 | 07:19 AM
wssix99's Avatar
Save the manuals!
We have a non-sponsor solicitation policy, so many retail links will run afoul of that.
You can read up on the parts at the manufacturer's website and hunt for a retailer from there: http://tiltonracing.com/product/75-s...cylinder-kits/
Old Mar 13, 2018 | 08:07 AM
Self-adjusting pressure plates adjust with the wear of the clutch disc. If you remove a clutch disc that measures .260" for a new one, it's like you just installed a disc that's .050" too thick. It over compresses the pressure plate. There is a way to reset the pressure plate, however, but it involves a press and a couple of people.
Old Mar 13, 2018 | 08:29 AM
johnfin's Avatar
Default Math
How can smaller be better she said. Math just doesnt work. P=f*a hence if the area a is smaller the pressure P is smaller. Bigger is better, right?
Old Mar 13, 2018 | 10:38 AM
Darth_V8r's Avatar
Moderator
Self adjusting plate attempts to keep the engagement int he same spot as the clutch wears. You lose return pressure, so it very often presents as the pedal not returning to full height. Many clutch "hydraulic" issues are actually misdiagnosed pressure plate issues due tot he self-adjuster
If you're talking about the clutch discs and pressure plate, Smaller clutches tend to have multiple discs for far more area. Math does work
If you're talking about the master cylinder, that's about mechanical advantage. The pounds per square inch to move the pressure plat fingers is the same. A smaller master means the area is smaller, so the square inches is smaller, so the total pounds of force is less, so your leg feels less effort. You make up for it in having to move your leg further to engage and disengage the clutch.
That's also why the 7/8 master is harder to push. you lose that mechanical advantage
Old Mar 13, 2018 | 12:41 PM
johnfin's Avatar
What size is the factory mc. My c5 vette clutch pedal releases near the floor and its super easy to move.
Old Mar 13, 2018 | 02:18 PM
Darth_V8r's Avatar
Moderator
3/4" factory
