The last inch
Used to have issues getting it lined up, dropped the trans back out and redoing the PP install several times. Use an input shaft and bam, perfect everytime.
What on earth do you need leverage for ? They're just for aligning the discs, not operating the clutch !
RAM 03-13 is a metal tool if need something to beat stuff with.
https://www.summitracing.com/int/par...-013/overview/
IDK about LSx but would assume same thing as LT1..or any other stick car
My McLeod Twin is same size PP as single disc clutch
IDK about the Monster...if it is smaller and does fit and since the FW is already on and you can access the bolts go for it
I can see some marks in the face of the pilot, any reason to be concerned that the actual bearing would be damaged? I did put some force on the tranny with rope wrapped around the back, and by using a small crowbar from inside the car (Not so much that it would deform the cutout in the trans tunnel). Some of the marks are from when I put it in the crank too.
also my last thought of a possible issue is the new slave, it looks slightly different and is slightly longer than my original, however monster assures me that it is the right one and the difference is a dust cover.
The marks on the bearing could be from installation ? But the needles etc all look to be ok, so I wouldnt be too worried about that
With that large single spline on the discs, it should make it even easier to get everything aligned smoothly.
The bearing looks to be OK.
Yeah I see you can access PP bolts with BH on, I don't have a LSx
Given the shape of the hat (PP) feeling around edge doesn't look like that would work to see if disc was even all the way around as the casting extends past the disc contact area. If bell housing wasn't on you should be able to see though
You are not alone in having to pull tranny and realign disc before...
If you can access the pressure plate with the bell on you just put the pilot tool in and compress the pressure plate , I made a handle with a swivel and tube so I could push on the throw-out bearing surface and release the clutch so the tool could easily align the disks. I used 3' of pipe for a handle and a random piece of 2.5" tube for the anvil.
You flat out have a disc alignment issue.
But really after about the 15 times or more I’ve put one in with the plastic tool I’ve gotten good at it. On two different cars when I’ve had lots of trouble getting the trans to slide in that last little bit I have taken a jack and put it up under the bell housing and jacked up a few inches. Amazingly after that the trans would slide right on in.
With the trans out of the car I’ve noticed the engine will lean back against the firewall. So basically without the trans bolted to the engine and the trans mount holding the trans in place the engine sits at a slight angle from when everything is bolted in place.
Ive pulled them in with bolts before which I do not recommend and just dent the outside of the pilot bearing a bit.
I say say align it best you can with the plastic tool then measure from each side of tool. That way you can see if if it’s cocked to one side or not. That should help to get it centered better. If you can wait get a metal tool or an old input shaft. Even then it’s not gonna be easy to slide the trans right into place.
