The last inch
Ensure the trans face is parallel to the BH face.
If it helps stick a bolt or two into the top to carry some of the weight and then give the trans a good wiggle/shake to help it in.
Once on the dowels it'd be ok to use the bolts, but really you should not need to, but never from an inch away
IDK if the T.O./Slave is holding it back and if you would need to crack the bleed open a little to collapse it some...maybe someone can advise on that
At that distance the tip of the input shaft should be "inside" the pilot
1/4" away=yes because the input shaft is then "inside" the pilot
OP re-aligned the disc to get it from 1" away to then 1/4"...initially there was a disc alignment issue...1/4" away there was the TO spring giving resistance
