Rpm t56 vs magnum t56
So the time has come that i need to replace my t56. It grinds in 1st and 2nd gear and now its to the point that it isn't enjoyable to drive due to this. I have been looking at either the rpm stage IV or stage V but also have thrown around the idea of getting a t56 magnum. I know the magnum is stronger and many people claim it shifts smoother, even though personally having driven two tr6060 equipped camaros i didn't see much difference, but it is also more money and i still would have my old t56 sitting around which right now i dont have room for. My car makes 440 rwhp so a rebuilt t56 would handle that with no problem but i dont want to be questioning myself later as to whether or not i should have got a magnum. So a few questions...can i still use the same shifter i currently have with the magnum? Also i know you have to get the yoke on your ds changed out for a 31 spline unit, would i need to do anything else? Last what would you guys do? Spend about 4k for the magnum or go with a stage IV t56 for $2700 or a stage V for $3200?
I would just rebuild your current T56 in whatever "level" you feel you need...the IV, IMHO, would be enough for your power level....or just a good rebuild/refresh unless this is going to be a primary race car
just wanted to give a little update on this...so I had a local trans shop take apart the t56 and it was pretty rough. Needed new synchros, bearings, etc. and apparently they said 5th and 6th gear were done. So the shop I had remove the trans ended up ordering a son of tranzilla from rockland standard gear. Couldn't find a lot about this trans recently but a lot of older threads seemed to praise it and best of all it came with a 1 year unlimited mileage warranty. It was $2700 and sure I could of spent $1500 more and got a magnum but currently closing on a house so I needed the extra money. So far I'm happy with it I just hope it holds up for a long time.
Other than that it was same as any other Magnum ?
Not sure why it carries extra cost though...surely there would need to be more difference than that
