2002 clutch pedal spring
Yes! I removed the spring and the pedal is not extremely hard to press but have not had any issues with the engagement of the clutch. I guess due to the
stiffer pressure plate and the bigger bore of the master it is not needed. If need be i would put the old coil spring set up like 70's - 80's trucks had, would be a lot
easier to install.
easier to install.
I have the same MC and clutch and I remember reading to remove the pedal spring but I couldn't locate it. I'm not having any engagement issues and the clutch engages more to top of the pedal than at the bottom. I don't think removing the spring will change this but could you post some pictures of where the spring is located?
Save the manuals!
It's a real pain in the ***. Plan for a lot of time.
In this thread, I've pasted several links to other threads where people talk about how to do it. https://ls1tech.com/forums/manual-tr...rn-spring.html
does leaving the spring on with after market MC and clutch cause and damage to the pedal? cause my clutch pedal pivot point broke off due to the constant presses it went through after only having the tick and ram hd clutch/pressure plate for a little less than a year.
