T56 magnum reverse lock out kit....or not
Old 08-26-2019 | 08:10 PM
Bobby G's Avatar
Default T56 magnum reverse lock out kit....or not
I'm doing a ls3 t56 magnum swap....I got a reverse lock out kit with it.....PSI is saying I dont need it because the computer does the reverse lock out....is this true or do I need the kit?
Old 08-30-2019 | 06:38 PM
stevieturbo's Avatar
Depends what "computer" you're using. I doubt your home PC would do it.
Old 08-30-2019 | 07:29 PM
rising_4rm_ashes's Avatar
Is this a T56 (TR6060) Magnum modified for F-Body or a stock form Magnum?
Old 09-02-2019 | 05:02 PM
Bobby G's Avatar
This is a LS3 Crate motor with a New Silver Sport T56 Magnum Kit.....GM computer
Old 09-02-2019 | 05:09 PM
If it's a stock computer, then let it do its job, part of which would be to control the reverse lockout. Your wiring loom should have the connector etc for it.
Old 09-03-2019 | 11:25 PM
Bobby G's Avatar
Ok....so I don't need the reverse lockout box that came with the transmission?
Old 09-03-2019 | 11:32 PM
Bobby G's Avatar
I have a PSI wiring harness and there is a plug for the so am I correct in saying that I don't need that control box from Silver sport?
Old 09-04-2019 | 12:50 PM
The GM ecu would normally control it....so again, if the wiring loom etc is correct and ecu correct, then it should control it still.
