Pilot bearing 2005 gto engine from 2006 trailblazer ss
So I just ordered my new ls7 clutch kit which included a new pilot bearing . This kit will be going on an engine i pulled from a 2006 trailblazer ss and is going in my 2005 gto (t56 m12 trans) trying to install dorman Part # 690-057 bearing . However when trying to install the new pilot bearing I was unsuccessful with the ‘ol hammer and socket method and damaged the front of the bearing beyond my comfort ! So now I have a question in my mind of if I wasn’t able to install it because it’s the wrong size possibly ? I froze the bearing 24 hours and also made sure to tap it in square before any hard blows with a hammer . Any help is super appreciated ! Don’t want to buy another bearing that’s the exact same just to damage it once more .
I order specifically for a 06 gto which is the ls2 bearing , then I actually just tried with a ls1 bearing after reading some forums and people saying that’s what I needed , still didn’t work . Is the back of the crank different or something in trailblazers since they never had an option for manual ? Starting to get frustrated with it and I’ve already spent over $40 in bearings .
Looks like your pilot bushings are measuring between 27.8 and 27.9 mm, butt the way you're measuring it (not that you have much choice) will result in a too-large error. 27.8 is REAL close to 1-3/32" butt maybe .002" larger so that makes sense.
Not seeing anything wrong there.
Post up a pic of the crank, and one of the back side (where it hit the crank) of a bearing that you reefed on but it didn't go in, and maybe we can guess what's up.
I used to buy those bushings in boxes of 25 for about $8 - 9 a box... I think I still have a box laying around with a handful left in it. MY how times have changed. and not for the better.
The following users liked this post:
LsJay04 (04-20-2024)
interesting , as stated I’m going with ls7 clutch kit which from my research says to use the ls1 flywheel and pilot bearing and I got it pressed it finally also ^ so I think I’m gonna give this one a shot . Now my question is if damaged it going in . Picture of damage is above also also , didn’t think the socket would dent it up that bad and I still think it’s fine honestly but want y’all’s opinion .
[QUOTE=LsJay04;20552898]interesting , as stated I’m going with ls7 clutch kit which from my research says to use the ls1 flywheel and pilot bearing and I got it pressed it finally also ^ so I think I’m gonna give this one a shot . Now my question is if damaged it going in . Picture of damage is above also , didn’t think the socket would dent it up that bad and I still think it’s fine honestly since no needle bearings were touched or harmed but want y’all’s opinion before bolting up this clutch/pressure plate .
if the needle bearings turn freely with your finger, its fine.
Next time use a wood dowel and hit that with hammer. I use a piece of closed coat hanger dowel.
anytime you need to remove it, use the blind hole puller. Autozone has it in their load-a-tool program. Easy to use
