M6 to A4 and A4 to M6 Conversion info requested
Originally Posted by 01CaMMMaro
im looking into going A4 to M6... will i need to replace the dash harness as well? also from what i understand the hardest part is the MC Ubolt.
doing an A4 to M6 conversion, does the pilot bearing for the M6 sit in the rear main seal housing? do i need to buy a rear main seal and housing for a M6 LS1?
Originally Posted by Blu99T/A
OK I read all 16 pages closely. After reading this I am confused as to what I need to do to get my cruise to work. I have a 99 t/a that I just swapped from an A4 to an M6
Anyway I also swapped the wiring harness so I have the M6 harness on. As of now I have the 2 wires from the neutral saftey switch jumped so I can start it, I know this needs changed and will be. What do I need to do get get my cruise to work?
The best I can understand is that I need to get a "Clutch Pedal Anticipation Switch" at least and wire it into the brake switch also in a series and then to where does it go?
Also since the swap, my TCS off light is on and will not turn back on, switch is non functioning right now. Will a reflash take care of it?
Computer will be reflashed Saturday with HPTuners.
Anyway I also swapped the wiring harness so I have the M6 harness on. As of now I have the 2 wires from the neutral saftey switch jumped so I can start it, I know this needs changed and will be. What do I need to do get get my cruise to work? The best I can understand is that I need to get a "Clutch Pedal Anticipation Switch" at least and wire it into the brake switch also in a series and then to where does it go?
im doing an 01 ls1 t56 swap into my 01 v6 auto camaro. i am getting a t56 wiring harness/PCM and t56 dash harness. will i need to do any splicing of wires or anything like that?
you might need to splice your reverse lights. I'm not sure if they're in that engine harness or not but I had to run a wire from the A4 shifter to the switch in the tranny. It's no big deal at all since you have to cut the hole anyways for the shifter, just either drill a hole or run it under that lower shifter boot. just make sure you get some kind of grommet for it or shrink tube and lots of tape. that's all I can really think of. the dash harness probably has the clutch safety start switch and cruise cutoff switches on it.
Im going to be doing an a4-m6 swap in the winter. Where are you guys getting your a4 to m6 conversion kits from and what else is needed besides the kit? Just a T56?
How much do the kits usually go for?
I read through most of this...but maybe I missed it...I hope someone can help.
Let's say I want to swap my auto for the 6 speed. If I have a donor 6 speed car that is putting a turbo 350 or something and won't need the wiring harness... what all do I need to take his wiring. Does the 6 speed wiring come seperate at some point that makes it easy to swap.
Basically what I'm saying is how hard is it to make a auto cars wiring look identical to a stock 6 speed wiring if I can get ahold of it all.
It took me like 2 hours to remove the whole ENGINE wire harness, but there is also an INTERIOR wire harness, which would probably be another hour or two. If you wanted to make it look stock you need the engine one, and the interior one also..
OK basically I jsut want to do an a4 to m6 swap.....i know i cant do it myself so who could do it an how much will it cost??? just plain straight up with everything....I'd rather pay the money and get it done right then mess stuff up an pay to have it fixed!
Well I just did one - and let me say one thing, unless you are there watching the shop you will never know if they did it right, I was swapping w/ a guy who was ALSO originally an automatic, but now an M6, and he wanted to go back to automatic, and the job they did on his car was real bad - tranny only had 4 bolts on it, among other stuff...
No I put it in right just that on the driverside it seems to far foward. Could there be a diffrence from the z28 to a trans am crossmember its out of a m6 2001 ws6 thats what the guy is tellin me
http://i86.photobucket.com/albums/k1...6/100_1031.jpg
