M6 to A4 and A4 to M6 Conversion info requested
Old Feb 26, 2009 | 11:03 AM
  #521
Stang-Slayer's Avatar
ehhhh i see....lol i guess that reverse lockout could be kind of important ahaha
going 65 and accidentally stick it in reverse hahahaha
Old Feb 26, 2009 | 02:29 PM
  #522
the_merv's Avatar
Well you are thinking of it opposite of how it actually is..then again from the way I said it, that didn't help either.
What I meant by function was that when you tune it, under 3mph it will open the Solenoid and allow you to go into Reverse easier, instead of have to force it in. It is blocked out of Reverse unless it gets the signal to open the Solenoid.
Old Feb 26, 2009 | 03:12 PM
  #523
Is it managable to drive at least for a little while though like that?
U think you could dmg something forcing it like that?
Old Feb 26, 2009 | 04:49 PM
  #524
the_merv's Avatar
It's manageable, I don't think you could damage anything..
Old Mar 5, 2009 | 09:43 PM
  #525
Black02SLPSS's Avatar
Well, im in the process of swapping out my a4 harness to an m6 harness. I completed the A4-M6 swap last year, and im curious about what the m6 harness will bring back. For whatever reason my cruise control does not work. Will putting in an M6 harness make my reverse lights work, reverse lockout work and cruise work? Im pretty sure it will make the reverse lights and lock out work but what about the cruise? If not what do i need to do to make it work? Oh and how hard does everyone think it would be to swap an a4 interior harness to the m6 interior harness? I guess the underdash harness?
Old Mar 6, 2009 | 09:28 AM
  #526
bjamick's Avatar
Everything will work just as its supposed it. You have changed your car completely to an M6 now and the harness will have everything on it such as the skip shift, reverse lock-out, cruise control will work all that good stuff.
Old Mar 6, 2009 | 09:45 AM
  #527
Sweet! Thanks for the good news answer.
Old Mar 6, 2009 | 08:44 PM
  #528
the_merv's Avatar
There is a Switch on the 1999 and up cars that goes on the Clutch Petal, it's called the Clutch Anticipation Switch. I know that one function of that is to turn the Cruise off, but you can actually wire that without that particular switch. PM me and I can explain it.
Old Apr 4, 2009 | 07:47 PM
  #529
Engine_HP's Avatar
WHY the PM say it in public im also interested.
Old Apr 8, 2009 | 05:37 PM
  #530
bjamick's Avatar
Hey Merv or anyone, it wont hurt the performance if I dont write entire will it? My tuner just changed it to where the speedo would read right and turned off most of the auto stuff to keep the ses light off. What you think?
Old Apr 8, 2009 | 11:02 PM
  #531
93cz28's Avatar
just finished the swap and my gauge cluster fuse blows everytime i put it into reverse.i used an m6 harness and when i put it into reverse the backup lights dont come on either. im guessing the 2 wires that were left over (green and brown) in the center console should go in place of the backup light wires on the tranny, because if i touch them together my back up lights come on. also its hard to get the car into gear when i turn it on. think i need to bleed the hydraulics a bit more?
Old Apr 9, 2009 | 09:20 AM
  #532
bjamick's Avatar
You can try the rev test to see. Rev it up in 1st gear and see if the car will move. That will tell you if it needs bled. Ya those wires go to the reverse switch.
Old Apr 9, 2009 | 10:21 AM
  #533
93cz28's Avatar
yea the car moves in first and all the gears go in fine now except reverse.i can put it into the gate but it just wont go in reverse. also the car wont start unless i jump start it. somethng is massively draining the battery really quick.and when i do turn it on it runs but then turns off while in neutral and wont turn on again.
Old Apr 11, 2009 | 11:16 PM
  #534
93cz28's Avatar
alright everything works great now. i have 1 suggestion about using an m6 harness.cut off the pigtail for the back lights off of the harness and cover up those 2 wires. elongate the 2 backup light wires from inside the car and solder on the pigtail. run that down and connect it to the back up light connection on the tranny. if you dont do that your gonna 1. blow your gauge fuse 2.drain your battery 3. your back up lights wont work. the only other wiring you would have to do if you use an m6 harness is solder the 2 wires inside the car for the hatch release together, and elongate the clutch switch wires and attach them to the black switch on your clutch. everything else is just plug and play.
Old Apr 13, 2009 | 08:35 AM
  #535
the_merv's Avatar
^^Cutting off that Pig Tail depends on the Car.. I wired mine in as it was factory and extended the Reverse Light wire over to it. I used the Auto Trans Power Wire that was in the Harness to power that circuit.
Old Apr 15, 2009 | 03:56 AM
  #536
Devils Mentor's Avatar
I will be doing a A4 to M6 swap soon so I need to reread this, but I thought I would ask.... Is there anyone here that is from Jacksonville Florida, or at least close that would be willing to help or for a fee, do the swap?
Thanks guys!!!
DM
Old Apr 15, 2009 | 07:48 AM
  #537
indirocz28's Avatar
If anyone is looking for a good Lsx 4l60e i have a very clean low mileage one out of a 2wd truck that was wrecked. 20,000miles on it....
Can send pictures.. I dont need it anymore i got rid of my lsx car- and this things just taking up space i really dont have..
$450 obo...
Will ship at your expense..
Old May 4, 2009 | 02:13 PM
  #538
MBC Racing's Avatar
so is the harness the COMPLETE engine wiring harness?
OR is there just a portion of it you can replace?
Looks like there are enough people switching from A4 to M6 and M6 to A4 to be able to just trade harnessses???
I am planning on M6 to A4, but was hoping to keep the pedels incase I ever go back..... Oh well. Maybe just easier to find someone do the opposite of what I am and trade out some pieces.
Anybody in IL doing this?
Thanks
Old May 13, 2009 | 02:00 AM
  #539
K6Ls1's Avatar
I would like to go to M6, but I'm in Georgia.
Anyone for a complete swap of my A4 for your M6, in GA?
Old May 25, 2009 | 09:36 PM
  #540
30th t/a's Avatar
A4 to M6 swap below.
http://www.gmhightechperformance.com...wap/index.html
