M6 to A4 and A4 to M6 Conversion info requested
Old Sep 15, 2008 | 10:07 PM
  #481
1st TA's Avatar
We are doing the a4 to m6 swap on my boys 94 Z28. I have read through this thread and there seems to be a question as to wiring the cruise switch on the clutch ped.. I have read that if you hook it up in series with the switch on the brake ped. it will work until you have the pcm re-flashed to the m6 trans. Is this correct? and if so is there a pin on the computer that can be tapped to go to the clutch switch to make it work as it should? Any help would be great. Thanks
Dave
Old Sep 17, 2008 | 04:35 AM
  #482
Engine_HP's Avatar
Originally Posted by the_merv
Here is a really good explanation of this for anyone that it can help.. about the best way to do it IMO..real close to factory.
In the Harness, strip out all the Auto Wiring except the wire that powers the Solenoids in the Transmission(it will be a pink wire, if you trace it, it will go to the Connectors on the Fender), and leave one other one inplace that goes to the PCM, you will need this one too.
Reverse Lights:
Take the Reverse Light wire off of the Auto Switch(Lime Green wire on the Auto Shifter Connector) and extend it over to the Harness Connectors on the Passenger Side. Connect it in on an open spot, and do the same on the Engine Harness side. Run a wire through the Harness and eventually to the Reverse Light Connector for the T56. It will splice into the Wire that's green on the Connector. (It will help to have a Tranny to measure the length) I placed it about 6" down from the branch in the Harness where the wires go to the Tranny, about 12" in length.
Reverse Lockout:
Take the Reverse Lockout Connector and lay it next to the VSS Connector(the wiring is about the same length). Take the Green wire and connect it to the one wire that you left(not the power wire), and then take the other end that's at the PCM and put it to the Pin on the PCM Connectors is the Reverse Lockout. I don't know what exactly the one is for the LT1's, the LS1 F-body's is PCM RED #44.
If you have done everything by what I just said at this point, you should have the pink wires left. You are going to connect the pink wires from the Reverse Light and Reverse Lockout Connectors into the one that I said to leave that was in the Harness, this will be the Fused Power for them.
That's about it..then go into the Interior and strip out the Wiring that is left over from the Auto stuff. Some Wires will be hot with the Key on, be sure to properly cap them off
Old Sep 17, 2008 | 04:00 PM
  #483
1st TA's Avatar
I was asking about the cruise shut off switch on the brake pedal. The info on the quote pertains to the safety switch, the reverse lockout, and the skip shift. Any one?
Need to know what pin on the computer to tap into for the grey wire to the switch.
Thanks
Old Sep 21, 2008 | 10:53 AM
  #484
bjamick's Avatar
Ok I took some pics of all the wires I have at the trans tunnel. Are all of these wires used?
I also took some pics of my connectors on the clutch pedal. (Pics make things alot easier )
Those are the only connectors I have on the clutch side.
Old Sep 21, 2008 | 08:56 PM
  #485
Engine_HP's Avatar
Old Sep 21, 2008 | 09:07 PM
  #486
Engine_HP's Avatar
Look at the diagram i posted up. its a lot of info
Old Sep 21, 2008 | 09:58 PM
  #487
bjamick's Avatar
Oh ok thanks for the info. The one that says "I dont know". You think that is what is used for the revers lockout?
Old Sep 21, 2008 | 10:14 PM
  #488
Engine_HP's Avatar
No..... the rev lockout comes from the pcm pin#44 red connector to the rev lockout solenoid and from the rev lockout solenoid to a power wire (pink wire).....
its all in the diagram i posted above...
Please look at it.....
Old Sep 22, 2008 | 09:56 AM
  #489
bjamick's Avatar
That diagram just confuses the **** outta me lol. I suck at this kind of stuff.
Old Sep 25, 2008 | 02:49 PM
  #490
the_merv's Avatar
I wish I could see them to help out.. the pics won't display..
Old Oct 7, 2008 | 07:08 PM
  #491
1st TA's Avatar
I am looking for lt1 info, I think this is ls1. Is it not?
Originally Posted by Engine_HP
Old Oct 8, 2008 | 12:48 AM
  #492
Engine_HP's Avatar
yes this diagram is for the ls1.
Old Oct 11, 2008 | 01:44 PM
  #493
yoeasy69's Avatar
Doin the a-4 to M6 swap.. heres a little back story..
got a new motor Lt1 383 stroker, can't put it in till christmas. (its in Mich.. im in Nc) but my tranny started throwing codes.. so i picked up a M6 swap.
it came out of a 94 camaro, and my cars a 96. the clutch still has some life in it, and i am going to use it till i put the motor in, when i can get a nice Spec, or centerforce.
With the Flywheel, clutch and pressure plate out of a Lt1 car before. going into a Lt1 car, would i need the flywheel rebalanced to the motor i have in the car now or would i just line the pins up and bolt her down?
when i do change the new motor, would i need to have the flywheel rebalanced for the 383 due to it being Centrally balanced, or will it not be a factor?
Thanks!
Old Oct 13, 2008 | 11:21 AM
  #494
the_merv's Avatar
The Flywheel is Neutral Balanced, it does not matter.
Old Oct 27, 2008 | 10:10 AM
  #495
bjamick's Avatar
Ok this weekend I got my motor put together and started working on the swap.
I got my pedals in and mouted up and then started looking at where to put the master cylinder. So I drilled a big hole and put the master cylinder in place. Man what a PITA that was. Took forever to get it straight with the clutch pedal. Had to keep grinding out the hold to get it straight. But I finally did get it installed.
Also got the neutral safety switch wired up, or all except for the reverse lights, bc I didn't have a connector that would work. Also gotta wire up reverse lockout still and then get the motor and trans put in at the same time.
Old Nov 3, 2008 | 01:25 PM
  #496
bjamick's Avatar
Hey Merv what did you do about your Skip Shift? DId you just leave it alone with nothing going to it? I was just wondering if I should get some skip shift eliminator or something?
Old Nov 3, 2008 | 01:33 PM
  #497
Engine_HP's Avatar
the skip shift comes from pcm 79 blue connector. then power by the other wire.
Old Nov 3, 2008 | 01:48 PM
  #498
the_merv's Avatar
I didn't even wire it in, and I'm pluggin it off on the Transmission, and getting it Tuned out when I get the Car Tuned for the Standard.
Old Nov 3, 2008 | 01:59 PM
  #499
Engine_HP's Avatar
And for the plugs u can fined the on ebay 11 $ each + shipping.
Old Nov 3, 2008 | 02:00 PM
  #500
bjamick's Avatar
Ok well i've got HPtuners so im guessing I can just disable and the light will go off.
Also the white connector on this pic from above, you said it comes from pin 32 but I dont have a connector that fits it. Do I need to buy one?
