M6 to A4 and A4 to M6 Conversion info requested
Old Nov 3, 2008 | 02:06 PM
  #501
Engine_HP's Avatar
sure u can pic one up from any trash camaro or u can make ur own one. but first u have to do some test to see wich 2 of those 4 u will need.
Old Nov 3, 2008 | 05:01 PM
  #502
bjamick's Avatar
Ok I just read through a few pages and found out that that switch is used for disengaging the cruise control by pushing in the clutch. This just means when I push in the clutch the cruise wont quit. No biggie really.
Old Nov 5, 2008 | 11:52 AM
  #503
the_merv's Avatar
^^There is one on the Brake Petal too that you will see, it's to dis-engage Lockup on the Convertor when you hit the Brakes. The other one on that Switch is for the Brake Lights, and the little single Switch is to dis-engage the Cruise Control.
I removed that stuff, the N/S Switch on my Car will be on the Clutch. I had to bypass it all with the Auto to get the Starter Wire to work, for some reason the LT1 N/S wiring wasn't working with my LSX Harness. Someone had messed with it before I got in there and messed it up.
Old Nov 5, 2008 | 05:25 PM
  #504
bjamick's Avatar
Well im still wanting my cruise to still deactivate when I hit the brake. Now that christmas is coming up alot of things are being put on hold til more money comes in.
Old Nov 5, 2008 | 06:22 PM
  #505
the_merv's Avatar
^^Yea, I forgot about that one, it's on the Brakes too..
Old Nov 9, 2008 | 06:15 PM
  #506
fbodyman1026's Avatar
I'm going to be doing a M6 swap on my a4 trans am. I am buying the transmission from my friends z28 with the T56. He is going to a TH400 w/ slapstick. So he is willing to give me all the parts I need for the conversion as long as he doesn't need them for his new TH400. My question is we can just switch pedals right? Also what hidden expenses are there that am not thinking of??? I'm buying the trans and shifter for $1,200. What else will i need besides: Fluid and Flashing the PCM.
Old Nov 9, 2008 | 06:24 PM
  #507
the_merv's Avatar
Yea, pedals will switch directly out..
Old Nov 9, 2008 | 07:27 PM
  #508
yeah I thought so.... I did some more reading and I guess I can follow one of the guides on the wire harness?? So i can use my auto wire harness and still have everything work correctly.
Old Nov 9, 2008 | 07:44 PM
  #509
the_merv's Avatar
^^Yea, as long as you wire the necessary things in it.
Old Dec 13, 2008 | 05:42 PM
  #510
Engine_HP's Avatar
Originally Posted by the_merv
^^That is one that I had mentioned about that is needed to pin if you want it to work correctly. For the LS1 F-cars it's PCM RED, PIN #44.
All the Auto ones except for the Fused power should have no signal once the Tune is changed.
hey the merv,
do u remember which wire (colour, pin #) in the a4 harness that is used for power.
Old Dec 18, 2008 | 12:30 AM
  #511
the_merv's Avatar
It will be a Pink Wire.
I used the Wire that was there that would normally power the 4L60E. It's not pinned from the Computer, it's on one of the Wheel Well Connectors, it comes from the Fuse Box. It will be the Wire that powers all the Auto Trans stuff if you look it up on a Pin Diagram. That is the one that I spliced to power the Reverse Lights, and the Reverse Lockout.
Old Feb 14, 2009 | 06:03 PM
  #512
multmigs's Avatar
Default anyone have the wiring on a LT1 correct
I have the needed pigtails for a A4-M6 swap on my LT1 but I can't figure out which wire goes to which side of the pigtails as they are the same color wire and don't have any marking that is refered to repeatedly in the common directions as either "A or B" so what do I do to figure this out.. Anyone have a photo or wiring diagram online?
Old Feb 20, 2009 | 05:57 PM
  #513
the_merv's Avatar
Here are some pics I found..
Reverse Lockout..
One wire goes to a 12v source, and the other goes to the Pin on the PCM Connectors that controls Reverse Lockout.
Reverse Lights..
One wire goes to a 12v source and the other is going to the Reverse Lights.
Old Feb 25, 2009 | 08:48 PM
  #514
Stang-Slayer's Avatar
Anybody know of any better write ups than the one on page one? It seems good but u know any others that have the pictures with the txt so u can see what their talkin about when their talkin about it?
Old Feb 25, 2009 | 09:23 PM
  #515
the_merv's Avatar
Try mine..
https://ls1tech.com/forums/lt1-lt4-m...onversion.html
Old Feb 25, 2009 | 10:54 PM
  #516
thanx man
Old Feb 25, 2009 | 10:55 PM
  #517
Do u have to get a whole new pcm to do this?
Old Feb 26, 2009 | 01:43 AM
  #518
the_merv's Avatar
Na, just re-tune it.
Old Feb 26, 2009 | 06:17 AM
  #519
will it work at all without a tune?
Old Feb 26, 2009 | 08:09 AM
  #520
the_merv's Avatar
It will still start and drive and stuff, but the Reverse Lockout will not function, and some other adjustments have to be made.
