M6 to A4 and A4 to M6 Conversion info requested
Old Nov 5, 2009 | 07:14 PM
  #561
the_merv's Avatar
Stock car?
Old Nov 6, 2009 | 04:14 PM
  #562
Mr. Trick's Avatar
Yes, the pcm did come from a stock 98 M6 LS1.
Old Nov 7, 2009 | 01:25 AM
  #563
the_merv's Avatar
I don't see why it wouldn't work..
Old Nov 7, 2009 | 09:37 PM
  #564
JohnFrazee02SS's Avatar
connect the orange w/ black stripe and the black wires directly together for the hatch release to work.
where are these wires at????
Old Nov 7, 2009 | 11:04 PM
  #565
Devils Mentor's Avatar
Lightbulb
Size:  3.8 KB You know what would be a good idea...
If someone made a video of how to do this and then rent it out or sell copies. I would be first in line for one!!! Just my 0.00002
DM
Old Nov 9, 2009 | 12:12 PM
  #566
Mr. Trick's Avatar
Right on, thank you.
Old Dec 4, 2009 | 01:23 PM
  #567
cure07's Avatar
I got a complete auto 4 setup with 60K miles on everything (2002 z28) if anyone wants to switch their manual setups for my auto setup. i live in Maryland so let me kno what ya want to do thnx!
Old Dec 7, 2009 | 10:51 PM
  #568
southpaw0314's Avatar
will a 98 t56 work in a 99 m6 swap
Old Dec 7, 2009 | 11:22 PM
  #569
themack56's Avatar
yes it will. i got swap parts pm me lol
Old Dec 21, 2009 | 12:54 PM
  #570
Batsword's Avatar
Would a stock T56 work if I'm also considering swapping to an LS3 at the same time?
Old Dec 30, 2009 | 03:32 PM
  #571
i just finished my swap to a t56. everything is done but i cannot get the car to start all the lights come on but it wont start. i haave tried connecting the clutch wires together but that still didnt work. any suggestions on what are appreciated. thanks.
Old Jan 1, 2010 | 08:35 PM
  #572
blazin's Avatar
Hey im putting a lsx/t56 into a 70s nova. I ordered a standalone harness for the car with a 60e plug and trans plugs. What all plugs will i need to rewire in there im assuming the speed signal is the same with 60e. Do I need to disect the stock 60e plug?
Old Mar 18, 2010 | 02:53 AM
  #573
Garry's Avatar
When doing a complete engine/tranny swap from a 2k to a 99, including the PCM moved over from the M6 to the A4, is there anything else to watch out for in the wiring apart from the parts like clutch sensor, reverse light and reverse lockout solenoid? Would like to keep the A4 harness, as I assume it's a major PITA to replace it ...
Old Mar 18, 2010 | 03:16 AM
  #574
the_merv's Avatar
Not really..it's pretty simple to work with.
Old May 21, 2010 | 09:03 AM
  #575
95/02ss's Avatar
The slave cylinder spacer for the LT-1 T-56 has been discontinued,as are some of the bolts. The pressure plate to fly wheel bolts(10079898) has been discontinued,The U-bolt for clutch master cylinder (14076942) has been discontinued,as is the console plate for the 6 spd.
I know I maybe able to source these from E-bay but most salvage yards around here are dried up to the 93-97 cars.
Hope this helps someone before they tear there cars down.
Greg
Old Aug 23, 2010 | 01:38 PM
  #576
White_TA_27's Avatar
I just did a A4 to M6 swap on my '98 and now have a problem with my my ignition. When I turn the car off and remove the key the windows, radio, and all accessorys work. When I place the key into the accessory location the car is in the off position. Has anyone had this problem, possibly just fliping a connector??
Thank you
Old Sep 12, 2010 | 10:15 PM
  #577
RedRallyeZ's Avatar
What are you guys doing with THIS cable after your A4-->M6 switch?
I assume its the ignition lockout cable that locks the key when you arent in park. Can i just cut it or would that perma-lock the system?
Old Oct 10, 2010 | 04:40 PM
  #578
Circa307's Avatar
bump cuz im curious as well
Old Oct 10, 2010 | 08:16 PM
  #579
RedRallyeZ's Avatar
i have since answered my own question.
it is the ignition lock cable. you can just remove it and youll be fine.
Once you take the steering column out, youll see where the cable connects to. Its just held on by two philips head screws. you MIGHT be able to undo it without taking out the steering column but i doubt it.
Old Oct 10, 2010 | 08:49 PM
  #580
Circa307's Avatar
cool man, im dropping the column anyways. btw im right below greenville sc
