Master Cylinder Hole
I am in the process of doing A4 to T56 swap. I have the pedals completely in and now it is time to drill the holes for the ubolt and the hole for the master.
If I look inside the engine bay it looks like there is a circle part about a little over an inch in diameter where it appears that I am to drill with the hole saw.
I havent seen or read anything anywhere about this little circle plate. It looks like it pops out for the master cylinder. I havent seen anyone mention it....
Any1 know what I am talking about?
Do I still drill or what??? Looks like this part is meant to be popped out in order to put a master cyl in its place...
Got your PM, I could snap a picture tonight of my firewall if you want (from the cabin side). Are there holes on either side of that larger one for the U-bolt clamp to slip through?
Nevermind guys...I got it. What I did is drilled the holes for the ubolt, easy.
Then used a peice of thin cardboard and cut out a 1-3/4" hole with the hole saw in the cardboard. Then I put the cardboard peice over the master cylinder and marked where the bolts go.
I then took the cardboard peice and put it up against the firewall, lined it up, and used the hole saw to drill the hole. It worked perfect!
I will have a full set of pics to put up once I am done with the entire install...
I just put up pics in the A4 to M6 sticky thread too (from my swap in 2002). No captions yet.
A4 to M6 swap pics
A4 to M6 swap pics
Congrats on the swap. I finished mine 2 weeks ago. I drilled a 2" hole and found out that's a little too big. Now I got about 1/2" gap above the MC and firewall.
Ryan
Ryan
