rear bushing in T-56
Old 04-05-2005 | 04:53 PM
02jaxz28's Avatar
Default rear bushing in T-56
I think the rear bushing in my trans. is going out. How much should I expect to pay for the repair if I pull the unit myself ?
Old 04-11-2005 | 03:47 PM
Z284U2TRY's Avatar
the bushing that is directly behind the seal in the rear of the tranny that holds the drive shaft in place? Whty do you think its going out?
Old 04-11-2005 | 07:34 PM
Krab's Avatar
Or are you talking about the tranny mount between the crossmember and the tranny? If so, it's very simple to do yourself if you have any type of experience with hand tools.
Old 04-13-2005 | 02:07 PM
jmd's Avatar
jmd
If you handed me the transmission, it would be a 30 min. repair. I don't know what your shoppe charges / hour.
Old 04-13-2005 | 03:26 PM
1madss's Avatar
Yep. This is an easy one. You only need to remove the extension housing and press/drive out the old bushing and the drive/press in the new one. No internal to the tranny needs to be touched. But just wait until you try and put the driveshaft back in
Old 04-13-2005 | 04:56 PM
thesource's Avatar
Do you have a vibration or a rear leak ? If not the bushing is probably fine .
Old 04-15-2005 | 03:01 PM
02jaxz28's Avatar
yes, I have a pretty bad vibration at 65-75 mph. it doesn't matter what gear the trans. is in, and I've already swapped out the rearend, and have had about 4 different sets of wheels/tires on the car. Oh yeah, I also swapped out the d/s with another aluminumn one. I did a search and found a couple of others who had the same symptoms and it turned out to be the rear bushing.
Old 04-15-2005 | 03:12 PM
thesource's Avatar
Thats very possible . I was just checking with you about it before you jumped the gun .
Old 04-15-2005 | 03:51 PM
technical's Avatar
Sounds like the tailshaft housing bushing is kaputz.
