HELP ASAP In the middle of a spec install!!!!
Old Apr 25, 2005 | 09:29 PM
LIL SS's Avatar
Moderator
Default HELP ASAP In the middle of a spec install!!!!
Hey fellas..im installing my spec st 3 clutch and i did not get the shim for it. does any1 know what the size of the shim is? Wondering this cuz im thinking maybe i could just make one... thanks guys and hurry this is my DD and i need it back together tonight so i can get to school and work tomm!!!!
-Ryan
Old Apr 25, 2005 | 11:15 PM
Krab's Avatar
I remember reading on a post that the thickness was .055". Don't quote me on that though.
Old Apr 26, 2005 | 09:01 AM
ACW's Avatar
ACW
Probably too late now, but https://ls1tech.com/forums/manual-transmission/6152-question-about-spec-stage-3-clutch.html confirms it's 0.055"
here's some other misc info about Spec Stage 3 clutch installs and the shim/spacer, found while looking for the measurement:
https://ls1tech.com/forums/manual-transmission/199135-spacer-comes-spec-clutch.html
https://ls1tech.com/forums/manual-transmission/264285-shim-spec-clutches-where-does-go.html
https://ls1tech.com/forums/manual-transmission/256987-spec-3-shim-no-shim.html
https://ls1tech.com/forums/manual-transmission/223251-more-clutch-problems.html
https://ls1tech.com/forums/manual-transmission/115482-spec-3x-did-you-use-shim.html
Old Apr 26, 2005 | 09:12 AM
VaNDaL*SS*'s Avatar
hey thanks alot man! i am the one who wrote on LiL SS nickname. Me and him and our buddy Tj were doing it then realized we dont have the shim! but now we can finish it up today instead of waiting longer
Old Apr 29, 2005 | 09:22 PM
VaNDaL*SS*'s Avatar
just thought id let yall know everything was a success...but im reading some of these threads and im beginning to wonder i fi have a ticking time bomb under my car...what makes these things go boom???
Old Apr 29, 2005 | 09:25 PM
redline2k's Avatar
Just make sure you break it in correctly and you should have no problems
