Trans dipstick
Old May 8, 2005 | 01:24 PM
F-bodyLuv's Avatar
Default Trans dipstick
Ok fellas. now dont make fun lol. I CANT find the trans fluid dipstick on my 00 Z28... HELP.
Old May 8, 2005 | 01:28 PM
tippmann243's Avatar
an m6 dosent have one
Old May 8, 2005 | 01:36 PM
F-bodyLuv's Avatar
so what am i supposed to do to add fluid.
Old May 8, 2005 | 01:39 PM
Tally TransAm's Avatar
theres a fill plug on the driver side of the tranny
Old May 8, 2005 | 02:14 PM
what he said, there is also a drain plug on the pass side of the tranny
Old May 8, 2005 | 03:31 PM
F-bodyLuv's Avatar
I just hit 50k miles and was thinking about a trans flush, what you guys think.
Old May 8, 2005 | 06:18 PM
AW794's Avatar
Probably not a bad idea
Old May 8, 2005 | 10:30 PM
Silver6sp's Avatar
manual trans dont require the fluid changes like an automatic does, just remove the drain plug and fill the new fluid in the fill plug, just have fun getting the fluid in the hole. takes 4qts, just fill it until new fluid comes out the fill hole
Old May 10, 2005 | 09:31 AM
SS01RED's Avatar
My 95 TA's dipstick would always come loose and stick out of its tubing.
Old May 10, 2005 | 11:10 AM
Steve Burger's Avatar
LS1TECH Sponsor
There is an easy way to fill. Get a trans fluid funnel and clear tubing that will fit snug on the end. Run the tubing through the engine bay into the fill hole. Now you can fill from the top. Put a drain pan under the fill hole to catch any overflow. Also when you are done filling, put the end of the tubing into the drain pan and allow it to empty before pulling it back through the engine bay.
