best t-56 output shaft?
mine broke yesterday
http://www.fastrides.com/photos/mm/i.../original.aspx
what is the best.
hardened stock shaft
D&D modified viper shaft
g-force shaft
other?
also with either of the middle two are there any mods you have to do to the tail housing or the driveshaft or any other internal changes required for them to work?
thanks.
what is the best.
g-force shaft
other?
thanks.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
You will want a 31T shaft from the Ford aftermarket T56 . You will have to mod. the extension to accept the larger yoke & rear bushing.The shaft itself will need trimming for length as well. You could also go the Viper output route with the same mods required. The Viper is a 30T part (you said you wanted the strongest thats the 31T)
is the viper shaft a stronger alloy than a stock f-body? G-force actually uses a different alloy for the mainshaft so it's probably a lot stronger than the Viper shaft and you can still use a stock splined driveshaft. I would go G-force although it is very pricey. Just do it once and pretty much never worry about it again.
Greg
Greg
The Viper design is a 30T and is the same material( as all T56s) . The strength is simply a matter of girth.The 31T is still the max.( there are some obscure 32T shafts but will not be easily accomodated into your castings) I can't speak for the Gforce stuff 'cause I don't know.
thats what i thought i read... so in order to put in a 700 dollar main shaft i have to buy a 1000 syncro kit.
i would tend to favor the 28sp g force since i dont have to hassle with changing the driveshaft but i'm allready over their rating as well.. and i would rather snap the cheap ones than the expensive ones!
10 Second Club + 14 Second Truck Club
if you want to get going again quick i have the stock mainshaft from my car in perfect condition, $100.00 shipped
i switched to the 30 spline viper output from d&d.
30T Viper Output Shaft Conversion Kit for '93-02 F-Cars (D&D Part No. BG29, Price $799)
This kit contains a shortened 30T spline Viper OPS, 17T inductor wheel w/ 30T internal spline, 30T spline Viper slip yoke and bored out F-Car extension with big bushing and seal. You do not have to shorten your driveshaft. A core charge of $250 will be added to your invoice when you place your order and will be refunded when you return your extension. Cracked or broken extensions will not be accepted for credit
no thanks i have a backup trans on the way. need to get good parts in the broke one while its apart
g force said that to use their shaft you had to buy the gear sets and synchros', meaning over 3k. (they can also do a viper upgrade to that one with their viper shaft)
Im not sure if chris still builds the trannies.
its something like jennings eng, or racing freaks, something like that
he local to me, herd alot of good stuff, had a buddy with a stock rebiuld and the tranny shifted amazing.
his screen name is 'Freak Z'
Ed
Ed
