change the pilot bearing???
Originally Posted by BuckeyeROC
I'd get a new bearing or bushing. I went with a bushing. Borrow a blind hole puller from Autozone to remove the old one.
Originally Posted by joshp14
Or if you have a 10mm nutdriver and some grease or wet toilet paper around...that method works awesome IMO...
The bushing is simply the same thing without the needle bearings inside. You can pick this up from most any GM dealership for $15 give or take a few $100 depending on which dealership you go to
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
