Powershifting: The right way.
Right now I figure i'll do this, rev 2nd to around 5500 then extremely fast I'll flick the clutch and shift gears as fast I possibly can while standing on the pedal the whole time. Hows this sound?
Maybe I should do it w/ a 2-3 or a 3-4 shift though so I wont loose traction?
Whaddya know?
Your correct though, just stand on the gas and when you reach the rpm you want to shift at stomp the clutch and slam the next gear, if your quick and accurate you won't hit the rev limiter or gind a gear (so long as your tranny is in good operating conditon) I actually rev mine to 6K and then hit the next gear, I never hit the rev limiter either. I bet I'm cutting it extremely close though, cause the factory tach can't keep up with how fast the engine is actually revving, and the more power you add the faster the engine revs and the harder it is for the tach to keep up.
Good luck, powershifting is addicting
thats true, if you plan on racing its good to just get a shift light. you can set the rpm to come on, and then depending on your reaction time you can shift slightly after that. after I installed my Harlan light I noticed how dangerous it was when I was looking at my tach so frequently. with a light, you get more consistant and you can keep your eyes on the road too.
Its called speed shifting. Tats what I do. Ive seen too many people screw a tranny on ONE missed powershift. Not the chances I like. If I miss speed shifting, it just doesnt go into gear.
I power shift all 3 upshifts w/ a shift light. It is wear & tear no matter what if you do this. Drive the car hard, expect things to break.
Thats right I am on my 4th trans (23k) I just put the last one in last friday (a weekago) 3ed is grinding today
And this one was saposta have everything doen to it, even cyroed gears. I bought it used form Ron over at hardcore motorsports and it worked great until I started to spray it. oh well the old one is going in to be proshifted soon for next year. Trending Topics
They're pro shift trans's & the face plate sets they're talking about w/the T-56.
If I rev all the way to redline and I clutch at 6000rpms then Im definitely probably gonna hit the rev limiter in my stock car. I can shift fast, but damn!
Should I not redline? wont that slow me down?
I believe I gave you some useable info in MY post, which was the FIRST reply you got. I'll add a bit of info to try and help you some more. Hand postioning has played a major role for me in quick, accurate shifts. For the 1-2 shift I just hold it with my thumb pointing up, gripping the right side of the shifter ****, and pull straight back. For the 2-3 shift I let the rear of the shifter rest in the palm of my hand and push straight up, sounds weird, but trust me, it works flawlessly if your hand postioning is correct. For the 3-4 shift I have my fingers in front of the shifter, and where my fingers end and my palm begins, right at the curve on the front of the shifter, and pull straight back. Alot of people tend to "grip" the shifter for all shifts and this is what causes most mis-shifts IMHO. Try these hand postions during normal driving to get used to them, and then let er rip, I'm sure you'll be slamming gears like a pro in no time. I have taken SEVERAL people for a ride in my car and have gotten numerous props on my shifting. In fact, I seem to be the standard in my area for what a great driver/shifter should be like. The look on peoples face or the words outta their mouth after I matted it in 1st, powershifted the 1st four gears and let out at around 120 is PRICELESS. GOOD LUCK MAN!!!! Once again I said this is not the place to say it, because this is a thread about powershifting, but since we are talking about shifting I thought Id bring it up.
