Installed skip shift - now can't get reverse!
Old Aug 21, 2005 | 08:02 AM
The Josh's Avatar
Default Installed skip shift - now can't get reverse!
WTF! I did just like the instructions said installing my CAGS eliminator and now, it still makes me go to 4th from 1st and it is VERY difficult to get reverse!
I plugged it into the only solenoid I could find. It was on the drivers' side of the transmission up high.
What now?
Thanks in advance.
The Josh
Old Aug 21, 2005 | 10:25 AM
lsp408's Avatar
if you did it on the driver side very top(next to shifter tower), that is the reverse lockout solonoid!!! the one plug right below it is for speedo. the one is on the driver side middle of tranny that is like 45 degreed point it down, that is the skip shift
Old Aug 21, 2005 | 12:03 PM
SporkLover's Avatar
sounds like you installed it on the wrong spot. www.installuniversity.com has good pics.
Old Aug 21, 2005 | 12:54 PM
The Josh's Avatar
Now I feel like an idiot.
Tell me, I didn't screw up my car by installing this wrong, did I? I am gonna git 'er done this week.
Thanks
The Josh
Old Aug 21, 2005 | 01:18 PM
1bad2k2ta's Avatar
You're not an idiot, but you gotta admit, that's pretty funny.
You just invented the !reverse! ROFLMAO
Old Aug 22, 2005 | 01:35 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
My next door neighbor was trying to hook up the backup lights on his '70 vette with a t56 and wired it to the reverse lockout instead. He installed a new shifter at the same time, so he thought he screwed up the shifter install. Needless to say, he was happy to find out it was a simple wiring problem.
Old Aug 22, 2005 | 02:09 AM
WS6 Kid's Avatar
All you have to do is put the resistor in the right plug and your car will be fine.
Old Aug 22, 2005 | 07:06 AM
ss1129's Avatar
yup I did the reverse delete once too. oh the shame.
Old Aug 22, 2005 | 12:53 PM
DONAIMIAN's Avatar
yup up high on the tranny on the drivers side is the reverse lockout.
Old Aug 22, 2005 | 01:16 PM
The Josh's Avatar
I remember looking and not seeing any other solenoid connectors on the tranny. I am going to look again though when i get it to a shop and up on the lift.
The instructions said it was a blue and white connector. Well, the reverse lockout is also blue and white. WTF? Needs to be better color coded...
The Josh
