probably goin to do drill mod and bleed it
To bleed the system, you're going to need an extra person helping you out. Have your buddy in your car pump the clutch pedal a couple of times then hold the clutch pedal down, you'll be under your car while he's doing this looking for the hard to find bleeder valve. It's located on the driver's side of the bellhousing (tranny) at about the 10 o'clock position. You probably won't be able to see it, but it's there. It's a 7/16 socket if I remember correctly. You'll want to use a 1/4" breaker bar so you can crack open the valve and close it quickly. Ok, while he's holding down the clutch, you're going to crack open the bleeder valve, let the fluid come out, then close it back up. The clutch pedal should be pressed down this whole time, then when you close the valve, your buddy can release the clutch. Repeat this process until all your old fluid is bled out. Just remember to keep a close eye on the reservoir, do not let it run dry, or you'll suck air into the lines. It's a faily small container, so do the process about two times, then fill up the reservoir.
Once you get all the old fluid out, you can use the mityvac method to get any extra air bubbles out (you will have air bubbles). You can use one of the needle tips on the mityvac and stick it in the hole at the bottom of the master cylinder reservoir, just be sure the mityvac line has a bit of fluid in it before sticking it in the hole. Now, you want to hold the mityvac so the line is vertical and start pumping that sucker up to about 22 in.Hg. You'll see small air bubbles travel up the mitcyvac line. Just leave it like this until you get very few air bubbles, then release the pressure and close the reservoir up. To get extra air bubbles out of the system, pump the clutch pedal a couple of times, then do the mityvac method again, you'll probably see more air bubbles come out. You can repeat this method if you feel you still have more air in the lines, which you probably will. Good luck!
