Ram powergrip HD is a piece of *&%@, only 500 miles on it and its slipping like crazy
I had a Ram powergrip HD installed along with a brand new ram billet steel flywheel. worked great for about the first 400 or so miles of easy driving. I got about 6 motor passes on it and 4-5 nitrous passes on it. and that was it, it started slipping like crazy! i was very upset, but atleast I could still have fun with it on the street right? WRONG, the next time I took it out, just cruising along, if i step on the gas anymore more than very easily, it will slip like crazy, rpms will skyrocket, and car will just not go anywhere unless i really ease into it.
I definitley think I got a defective clutch, my buddy has around 10,000 miles on his Ram HD clutch and well over 50 track passes, and the worst part of it is, his weighs like 200 lbs more than mine, makes atleast 50 more hp than me and always launched on slicks!
I am very very unhappy that I just spent all this money and only got about 500 miles outta this clutch.
Ram doesn't wanna replace it, and the sponsor who sold it to me doesn't wanna help me out either, they say its upto ram.
Originally Posted by 2001stripper
Why would Ram not cover replacing it?
One of the Ram techs told me before that there clutches last anywhere from 5000-20,000 miles. boy were they wrong. I certainly hope that anyone else that buys a ram clutch has a lot better luck than I did.
My POS stock clutch lasted 75000, I beat the hell out of it, and even at 75,000 miles, when it failed i found the disc itself still had plenty left. 'Twas the hydraulics that failed !!
That was before heads/cam tho
What a total rip. That is total bullshit. What really gets me is the vender won't help you out any. They should eat a 400 dollar clutch for the thousand's you've spent with them.
Yea it is bullshit when venders and manufacturers dont bakc up their warranties. I am going through the same thing right now with a shop and LUK (Pro Gold clutch). Only 5000 miles and it slips now. I keep telling them I need a pressure plate, but ehy keep telling me to do stupid **** like removing the clutch pedal spring! I still did that, and what do your know?! It didnt fix the problem because the PRESSURE PLATE is bad. Everyone wants to say the problem is not with thier product but something else.
BTW...what vender did this to you? Just for this boards info and customer safety.
Originally Posted by MagikMan
you are supposed to break it in for 500miles before you drive it hard........
Robinator, i made a seperate thread in the LS1TECH Sponsor Feedback section.
I just bought one recently from TSP and Mike at Ram and TSP both said to break it in for at least 250 miles before any track use or dyno use. Did you use an adjustabler master or the shim?
wrong! The ram powergrip heavy duty clutches do not have a break in period. I was told this directly from Ram.
Originally Posted by ElChiefWS6
I put a LUK clutch in my car and I have the same problems you are having. Thye told me the same bullshit excuse about removing the clutch pedal spring.
They will recieve an ear full from me tommarow, and they will proceed to tell me that only the shop can get any kind of warranty. I will then become very angry and yell at them some more and explain how the shop keeps putting me off (havent even gotten a returned call for 2 DAYS!! I have called them about 3 times a day.) Maybe the Buearo of Automotive Repair will help me out. I am on my last straw. Its been 3 WEEKS since my problem has occured and I keep telling them I just want the car fixed. I am affraid that this problem is screwing other things up like the TRANSMISSION! Why did I ever take my car to the shop? I can do all this work myself. Oh yeah, I didnt have time. Next time, I will MAKE time to do **** because if you want something done right, you truely have to do it yourself.
taking deep breaths now...
Did you ever stop to think that the installer screwed it up? That is the biggest variable, not the clutch manufacturer's quaility control. Any contamination on the surfaces will ruin it.
I have a Ram and it has never hinted at slipping.
LOL...the shop screw it up!? Wow, they dont screw things up when they intall parts! They are PROFESSIONALS. (extreme sarcasim) They tell me that they didnt screw anything up and they did everything by the book and its something else.
I feel your pain man. I had a Ram Power Grip HD go out with less than 2k on it and a VDS do the same with about the same mileage. I did more than the break in period, no track passes, and very few WOT runs. Ram worked with me and the sponsor that sold me the clutches. If it's worth anything, I'm running a Spec Stage III and it's been great. Of course, your results may vary. Best of luck.
