fedup, pissed off, frustrated!
with bleeding the damn hydraulics of the clutch, i must be a damn idiot but i CANNOT get the air out of the line!!! i've bench bled, tried every method of bleeding possible from mityvac to a;lskdjgh fl;akjfesh;agdsh peqv imogf!!!!!
i've been back and forth EVERYDAY to the auto hobby shop tring to figure this **** out, basically i gave up after today, im taking it to the GM dealer and just paying them to do it...FU&*k88ciakpioabhjksdnvurvnupw;akl!!!
6600 rpm clutch dump of death Administrator
Dumb question, but what are you doing to bleed the system? The clutch doesn't bleed like brakes (pump and hold, then crack the bleeder).
Its sorta the opposite. Crack Bleeder, depress pedal and hold down, close bleeder, repeat. Pump and hold won't remove air.
No Dealer!!!
yo if u have a 98-00 or an unfortunat 01-02 and u kep bleedin and seein air comeout then ur clutch pedal is fine right? then after a while it gets soggy again and u find more air right? Did u check that rubber boot for a hole even pinsize? if thats not it we in the same boat, but i know whats up... its ur slave cylinder leakin... after u bleed it watch were u park and u will see a wet spot on the floor... looks like between ur oil pan and transmission, some may say its ur rear main gasket, buts its ur slave leakin! Dont go to dealer or if u go lemme know if that was it... im just waiting for clutch master and upgrade slave to comein to replace all at one time cuz slave replacement needs tranny dropped, VERY EXPENSIVE AT DEALER!!! lemme know wassup
Jon
Originally Posted by y2k2z28
I've been having the same problem with mine. Mine is so bad that while sitting still I have to pump the pedal a few time to get it to shift into gear. I understand your frustration.
Jon
Started my clutch swap a week ago. If I only knew before what I know now, could do one in a few hours now with all the short cuts.
When I took it apart the inside of the bellhousing was clean so I did not replace the slave. put it back together and bleed just to get the air from the QD out and my dump *** friend lets the it run dry. that was saturday. Bought the mittyvac helped alittle but still have to pump to get it in gear at a stand still, then its fine until I stop again.
A buddy of mine is coming over with a vacumm deal over to pull vacumm from the bleeder value, which is most likely what the dealer will do. I will let you know if it works.
im just tired of pulling the clutch hydraulics apart and putting them back together with no possitive results. so ill let the dealer do there thing and see how that works out...
Originally Posted by ninobrn99
so is it that your pedal is going soft or that its not going into gear?
