Clutch Break In -> Got on it a bit, did I mess up the clutch??
Old 04-08-2002 | 04:07 PM
Stick only's Avatar
Default Re: Clutch Break In -> Got on it a bit, did I mess up the clutch??
Break in involves seating the disc facings into the flywheel and pressure plate surfaces. When the disc is new, it will have some high/low spots until it makes full contact on the friction surfaces. If the clutch is worked hard prior to break in, it will not be able to apply its full clamping load.
Old 04-08-2002 | 04:22 PM
MAFs 00 Ws6's Avatar
Awesome thanks for summing that up for me. By hard is that pertaining to take offs? If you get on it in 2nd -to- third is that bad? I wasn't hard on the take off but I did get in it a little this weekend, I put maybe 100 miles on it before this weekend. Did I mess anything up by doing this or should I be ok. Thanks again..Michael
Old 04-08-2002 | 05:41 PM
MIGHTYMOUSE's Avatar
no high rpm clutch action during break in. them tha rulz.
Old 04-08-2002 | 10:53 PM
Brownie's Avatar
Michael,
Sorry no tech help here for you.
Just wanted to say that I saw your car up at Powerhouse Performance the Saturday before last. That is an awesome looking car! Just sweet lookin. How's living with that cage?
Hope your clutch is treating you well. Did Chris & John get it all sorted out?
Later,
Mike
Old 04-09-2002 | 01:47 AM
Default Clutch Break In -> Got on it a bit, did I mess up the clutch??
I was told that the break-in period is 500 miles. Now my question is, what excatly is being broken in, and why does it take 500 miles for it to break in. I just don't understand what excatly is the reason behind this. Any help will be greatly appreciated. TIA, Michael
<small>[ April 10, 2002, 06:59 AM: Message edited by: MAFs 00 Ws6 ]</small>
Old 04-09-2002 | 08:02 AM
Mike, Thanks really do appreciate it. Chris and John were able to get everything worked out, which was a big releif. The clutch is so far so good. As for the cage its not that bad. Once you learn how to get in and out quickly its all good. Doesn't take long to get use to the cage. Can't wait for the break in period to be over so I can take her to the track, I am dying to get out.
Thanks again everyone for chime in. So do you think that I will be alright if I only got into a few times last weekend or did I screw it up???
Thanks, Michael
Old 04-09-2002 | 09:17 PM
So if I got into it a little last weekend, did I mess anyhting up or should I be ok? What do you guys think. Thanks again, Michael
Old 04-10-2002 | 07:58 AM
TTT....what do you guys think..Thanks, Michael
Old 04-10-2002 | 11:31 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
I would not dump the clutch or do any full out runs... but a little 2500-4000 rpm action is okay from a roll IMO.
Old 04-10-2002 | 03:00 PM
John, good deal, thanks <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> Michael
Old 04-14-2002 | 05:05 PM
NastySSoo's Avatar
Ditto what Pro Stock John said. Im sure your fine <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Paul
Old 04-15-2002 | 08:09 AM
Paul - Sweeeeeeeeet!! thanks man, really do appreciate it. Only a few hundred left until I get to the track. Can't wait...thanks again <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> Michael
