whats the best rear end gears with a t-56
would like to know what gear is better 4.10s or 3.73s i would like to keep a good 1/4 mile time. but i want the car to pull hard though all the gears. <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
i am running 3.23's right now. and i also heard that with 4.10's u have to use 5th gear is this true?
Is there a site somewhere that allows you to figure out the mathematics of it all? I'm trying to decide between 4.10s and 4.30s. I want to have a nasty gear for the street but also put myself in the power as I cross the line. But not know how to calculate gear ratios to trap speeds to RPMs, I can't figure out which one. There's got to be a site out there that helps out.
Thanks,
Mike B.
Thanks,
Mike B.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by buschman:
<strong>I want to have a nasty gear for the street but also put myself in the power as I cross the line. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats why I run 4.71s <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I've been wondering the same thing. 4.10s or 3.73s? If no gas milage is lost, then I guess I'll go with 4.10s. But how does the stock rearend hold up with 4.10s? Especially with DRs?
i read that CARTEK is using stock GM 10 bolts w/ 4:10's and not having any issues. they are apparently doing something differant than everyone else. in a recent high performance pontiac magazine article they said they set up them up w/ 10 thousands clearance between the gears. this is supposed to allow more fluid between the gear teeth hence "cushioning" the blow of the launch. they said it is alittle more noisey than usual, but it lasts longer... i'm still having trouble deciding myself- 4:10's or 3:73's. i have heard that 4:10's have trouble hooking on the street...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fireball:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by buschman:
<strong>I want to have a nasty gear for the street but also put myself in the power as I cross the line. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats why I run 4.71s <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Geez Brian, that's like a monster truck gear <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> Can you hook me up with a site, formula, or advice on how to calculate which gear is right for me?
Thanks Bro,
Mike B.
Thanks Bro,
Mike B.
IMO unless you have an agressive Heads/Cam car churning 6800+ rpm OR your running a taller tire than stock (25.6 I believe) the best gear for street/strip is 4.10s.
www.prestage.com ... go to CAR MATH
<strong>Is there a site somewhere that allows you to figure out the mathematics of it all? I'm trying to decide between 4.10s and 4.30s. I want to have a nasty gear for the street but also put myself in the power as I cross the line. But not know how to calculate gear ratios to trap speeds to RPMs, I can't figure out which one. There's got to be a site out there that helps out.
Thanks,
Mike B.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mike if your car is still bolt on get the 4.10's. Mine went thru the lights at 6000 rpm according to the stock pos tach when I was bolt on. 4.30's would be too much for a bolt on car IMHO.
Bruce
Thanks,
Bruce
<strong>Thats why I run 4.71s <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Coach 02 M6 Z/28:
<strong>I run a little oh.... 5.13 gear in my M6 Hot Rod!</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"></strong>
Boy you guys make me feel like a weenie with my 4.56s, 4.30s, and 3.50s. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Any guesses on which gearsets go to which cars? <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by KTamez:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fireball:
Any guesses on which gearsets go to which cars? <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Fireball and Coach are using some "ignorant gears" for sure, but they are not using a 26 inch tire either (at least I hope not <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> ). For a bolt-on car w/a 26 inch tire use 4.10s and h/c car probably a 4.30 or so. JMO <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
