Why is my clutch pedel so soft?
My clutch has been, well not hard to push in, i have a spec stage 4 and most other Fbodys their clutches seem harder.
Well i just replaced the master (adjustable mcloud) and slave (02 slave) and it is realy soft right now.
Is there a way i can firm up the pedel feel?
Re: Why is my clutch pedel so soft?
I installed the mcleod with an assist from Reckless. It is rock-hard. Maybe your bleed did not get all the air out? A second set of hands really helps when doing a bench bleed. I did the drill out mod about a year ago.
I'll be road testing tonight and will let you know if my pedal does not stay firm.
Was the pedal pressure hard...and then gradually got soft?...or was it soft to begin with?...if it is the first...then check your clutch fluid reservoir...if you see small pieces of black rubber...then you got a defective Mcleod MC...(leaking seals) another symptom is an inconsistant clutch engagement point...I went through two of them myself...before I decided to make my stock MC adjustable...if it is the second option...then you didn't bench bleed it well enough...just pump the clutch pedal...have a buddy look at the clutch fluid in the reservoir...if bubbles form...then that's the air coming out of the system....just keep pumping until you get good pedal pressure...good luck man...
David R.
David R.
Try this and see if it helps:
https://ls1tech.com/threads/showflat...t=all&vc=1
Let us know.
Mike
Let us know.
Mike
