Clutch peddle sticks, when under hard acceleration
Old 05-28-2003 | 08:41 PM
Argon Z's Avatar
Default Clutch peddle sticks, when under hard acceleration
When im at the track at in first gear, doing a slow clutch drop my peddle sticks to the floor, the clutch is not slipping yet the peddle sticks to the floor, the it comes back up when im going about 45 and ready do go into second.
Old 05-28-2003 | 09:03 PM
Argon Z's Avatar
Default Re: Clutch peddle sticks, when under hard acceleration
i have mcleod master cyinder, spec stage 3, updated slave cylinder, drill mod.
I feel that it is bleed very well, that is not the problem.
Old 05-28-2003 | 09:07 PM
Assassin's Avatar
you may have a leak
Old 05-28-2003 | 09:12 PM
Argon Z's Avatar
no leak i checked the level in the resouvior and it looks full.
It is only in first gear.
Old 05-28-2003 | 10:26 PM
Assassin's Avatar
do you have the master cylinder pushing too far out? how far up does the clutch grab?
Old 05-28-2003 | 10:57 PM
Argon Z's Avatar
I have it engageing very high up, could this be the problem.
Old 05-29-2003 | 08:57 PM
wrencher's Avatar
wrencher
You should have it adjusted to where you have an inch of free-play in the clutch pedal b-4 it does anything. This ensures no pressure on slave clutch out hot or cold. Readjust & then check it out.
Old 05-29-2003 | 09:57 PM
Argon Z's Avatar
yeah i adjusted it way down, it was way to high up, we will see if it took care of the problem.
Thanks for the responses.
Old 05-30-2003 | 08:13 PM
Argon Z's Avatar
any one else, have any input. Like i said i find it strange becasue it works flawlessly until im at the track doing a clutch dump in first gear and the peddle just sticks to the floor while the clutch does NOT slip
