To Locktite or Not???
I'll be putting the T56 back in this weekend along with the new clutch and resurfaced flywheel. A question:
Do you used locktite on the following and what color (red/blue)?
Flywheel bolts to crank
Pressure Plate bolts to flywheel
Bell Housing bolts to block
Tranny bolts to bellhousing
Cap bolts on rear driveshaft yoke
Shifter Plate
Pressure Plate bolts to flywheel - Blue
Bell Housing bolts to block - None
Tranny bolts to bellhousing - None
Cap bolts on rear driveshaft yoke - None
Shifter Plate - None. Just use some goop around the perimeter to put a good seal on it
Shifter Plate
Red loctite on all but the shifter plate. For those use a bit of the same sealant for the plate.
On the flywheel bolts, make sure it's clean first before bolting it up with loctite. Same with the pressure plate. Do it once and do it right. If you have an aftermarket like a textralia, make sure the bolt holes have NO PAINT in them.
