Clutch help!!!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
ok i have a 98 z-28 , hooker lt's , heavy posi, lid, dual 2 1/2" pipe out back and etc, i need a good street and strip clutch.I run on drag lites with nittos. what all do i need? i mean do i really need a new master? also what about my slave . thanks also make sure you help me in detail. thank you <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
If your pressure plate and flywheel are in good shape I'd recommend just getting a Spec Stage III CERAMIC (not carbon fiber) clutch disc. That disc with all the stock GM stuff is holding 1.4X 60ft. times and 550rwhp on slicks.
It will chatter the first few hundred miles but that will go away after break in. You can get from Mark at Raging Motorsports for about $200.
so spec stage 3 clucth is good , also the rev loc 2 thats good ,what about a mecloud dual disk? or a single?, need info guys on a master and a slave also should i do the drill mod. thanks
yes <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> i would highly recommend the slave and master cylinder i got mine thru thunder for 2 something. that pedal stuck to the floor every time i floored it then when it was stuck i wouldnt go into gear <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> so i replaced it about 3 weeks ago and im very satisfied you wont regret it <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
