Spec Stage III ????
Old 06-29-2003 | 10:07 AM
sconnor's Avatar
Default Spec Stage III ????
I just had a Spec Stage III clutch installed in my 01' WS6 and it has major clutch chatter when I ease out of the clutch. The installer told me because it is a racing application you have to pop the out clutch faster. Is this true or is it a bad install???? I only have 100 miles on the install so it's fairly fresh so I don't want to pop it to fast. Any help?????? TIA...SCott
Old 06-29-2003 | 10:39 AM
Krazy98Z28's Avatar
Default Re: Spec Stage III ????
If you dont have gears you will get alot of chatter. Gears help get rid of the chatter and also once the clutch gets broken in enough you will lose most of the chatter.
Old 06-29-2003 | 10:49 AM
LOnSLO's Avatar
Give it about 400 more easy break-in miles, and most of the chatter will disappear.
Old 06-30-2003 | 04:13 PM
sconnor's Avatar
Will it damage anything during the break in with all the chatter????
Old 06-30-2003 | 07:34 PM
2001TA's Avatar
I just installed a stage 3. 300 miles on it now and almost all the chatter is gone. Feels like stock just a little stiffer
Old 06-30-2003 | 07:42 PM
sconnor's Avatar
Great!!! Thanks or the info......Scott
Old 07-01-2003 | 10:09 AM
SSactionLs1's Avatar
my chatter is all but gone but the squeek is still there when its cold...
Old 07-01-2003 | 10:05 PM
VSGLS1's Avatar
Anyone use an adjustable master cylinder when putting in a S3?
