which sfi bellhousing to buy
Old 03-01-2008, 09:43 PM
darrellk's Avatar
Default which sfi bellhousing to buy
which is the best and easiest sfi bellhousing to install, im about to put my motor back in and want to put a sfi bellhousing on. any feed back on any of them would be appretiated, thanks
Old 03-01-2008, 10:01 PM
bigdsz's Avatar
McLeod makes the only one I am aware of.
Old 03-02-2008, 12:13 AM
CW00BlackTA's Avatar
You want the Quicktime unit--it's lighter and easier to install than the MacLeod.
Old 03-03-2008, 11:18 AM
darrellk's Avatar
so u have installed a quicktime on your ls1, no real problems
Old 03-03-2008, 08:37 PM
LS1TECH Sponsor
badpewter-z's Avatar
the mcleod is a solid piece but takes some finesse, patience, and some griding to fit along with a few choice words
Old 03-04-2008, 06:08 PM
darrellk's Avatar
would it be better to install be for i put the motor in, my headers face forward for the turbo so i should not have to worry about that what other issues are there wiht the mcloed bellhousings
Old 03-04-2008, 06:41 PM
LS1TECH Sponsor
you should be fine but fit the motor plate to the motor(you will have to grind the oil pand and block) while on a hoist . also enlagrge the starter hole and make sure it fits nicely first, i found that one out the hard way. also you will need some allen head bolts to hold it together where as the regular bolts they give you will not fit the bell . also line both pieces up and enlarge the holes youll be using to hold the 2 pieces together and the bellhousing ones slightly so as there not overly tigth with no movement. it will make life ALOT easier . thats about what i can think of for now
Old 03-05-2008, 05:37 AM
darrellk's Avatar
thanks
Old 03-05-2008, 09:32 PM
1QWIKBIRD's Avatar
This is good info...I had to do all the same things. If the motor is out of the car, its easy....in the car it might test your patience some.
The quicktime unit looks easier to install, but not sure if it comes with the block plate or not? Without the block plate I'd say its not offering the same level of protection as the McCleod unit. I have not seen a quicktime unit in person so I could be very wrong, but its something to look into.
Old 08-11-2008, 12:38 PM
2002_z28_m6's Avatar
Slowhawk installed a Quicktime and he said it was a lot easier than the Mcleod and that it fit better. It does come with a block protector plate. Thats the one i am going with. Sounds like both can be a PITA though.
Quick Reply: which sfi bellhousing to buy
