adjusting MC
but to the original poster i highly doubt you will have a problem over extending the slave
Other possible solution is the Ram master still has the stock internal stop?
I on the other hand used the mod to extend my pedal possition. i didnt cut a section of rod off, rather cut it in half and extended the rod w/o it hooked up giving me a higher pedal. i had to for my swap. if i wanted to i could also get more throw out of it by extended the other portion of the rod into the bore. thats why i asked if anyone had ever poped a slave. youre wrong my friend
. I on the other hand used the mod to extend my pedal position. i didnt cut a section of rod off, rather cut it in half and extended the rod w/o it hooked up giving me a higher pedal. i had to for my swap. if i wanted to i could also get more throw out of it by extended the other portion of the rod into the bore. thats why i asked if anyone had ever poped a slave. youre wrong my friend
