Can't get master line off of tranny? Help!
Old 08-15-2003 | 03:52 AM
Bowtieman4life's Avatar
Default Can't get master line off of tranny? Help!
I used two screw drviers and pushed the white ring all the way in but the line won't come off. I spent two hours trying to get it off. Is there a special tool I can use? Is there another way to get the line off? Can I do the drill mods with the line connected to the tranny? Having a tough time.
Old 08-15-2003 | 06:56 AM
PongoX11's Avatar
Default Re: Can't get master line off of tranny? Help!
Yeah its #@&^#(*@#'ing impossible! I swear, I fought with mine forever, and gave up. Went back to it a while later and popped it right off in no time. You just need to push that plastic circle way it there. I heard there is a tool to take it off, but never bothered to buy one
Old 08-15-2003 | 12:01 PM
Proud2bSS's Avatar
Mine came off lickity split with two thin bladed, flat screw drivers. If I remeber right, it popped off. Of course, I had the back of the tranny hanging down about 6 inches so I could reach it easier. But bleeding the clutch line afterwards was a bigger pain in the buttocks (Forest Gump's voice dubbed in here)....
Old 08-15-2003 | 02:00 PM
I pushed that thing in so many times that I chewed up the ring. I am going to call GM and see if there is a special tool? Any ideas?
Old 08-15-2003 | 05:29 PM
buschman's Avatar
I don't know any specific tricks, but I know the 00 rings are tougher than the 02 rings. It should make a snaping sound when you get it right. It can be such a hassle at times. They make a special tool to get the fuel lines off, so I guess it's possible that they make a tool for the clutch hydraulic line as well.
Good luck,
Mike
Old 08-15-2003 | 09:41 PM
Jason99T/A's Avatar
I can shift faster than you.
Yes, they do make a special tool for the hydraulic line. It actually is a Ford tool that most of the Snap-On, Matco, etc. dealers sell. I have also seen it available online and a local parts stores.
Old 08-15-2003 | 09:44 PM
Jason99T/A's Avatar
http://www.mytoolstore.com/kd/kdsusp06.html#3413
http://www.matcotools.com/Catalog/cr...3&si=37514
I have one from Snap-On, but it looks like almost the same as those above.
Old 08-15-2003 | 11:15 PM
I say that same tool at KRagen but thought it was too big. I know I got the ring in all the way at least four times but it won't disconnect. Driving me nuts.
