HELP, Lost "roll pin" while performing drill mod
Old 07-18-2008 | 05:36 PM
landonew's Avatar
Default HELP, Lost "roll pin" while performing drill mod
I know its stupid, but i lost the roll pin (the pin that connects the steel braided line to the master cylinder).
I was punching it out and flew across the back porch and I can't find it.
I don't want to buy a new $180 master cylinder just because i lost a stupid 2 cent pin. Is there any other option? I don't know anywhere i could find anything remotely similar to this.
Old 07-18-2008 | 06:20 PM
ROCNDAV's Avatar
You should be able to buy a roll pin at any decent hardware/automotive store. Sucks not to know the size of it though... maybe someone knows or has one taken apart so they can check for you. Worst case, you can take the master cylinder with you (if you have it out on the bench).
Old 07-18-2008 | 07:46 PM
firehawk238's Avatar
well first off i just picked up a brand new lifetime warranty master cylinder at oreillys for 35.00 and a slave for 40.00, but if you go down there and ask to see the roll pin out of the master cylinder box, you can go back into their dorman loose hardware and match it up with one. should only cost you about $.05, but to be honest for as cheap as the master cylinder id put a brand new one in since you have the old one out. ill never go back with a used one, or a used slave. too cheap to replace now.
karl
Old 07-18-2008 | 09:03 PM
landonew's Avatar
Thanks guys. I got one from autozone. The slave cylinder has 3000 miles on it, so i didn't feel like it needed to be replaced.
Old 07-20-2008 | 06:14 PM
Dwn Cam's Avatar
Mcleod Sells just the Roll Pin.
Old 07-20-2008 | 07:22 PM
Gauge's Avatar
11Second Club
What was the size of the pin (for posterity's sake)?
Old 07-20-2008 | 07:42 PM
landonew's Avatar
In all honesty I don't know. I had to buy a value pack (basically an assortment) and sort through them until i found one that fit. I can say that it is a common size, and that there were several that fit. Best thing to do is bring the master with you and test em out.
Orielly's was nice enough to open the value pack for me so that i could ensure it had the appropriate size.
Old 09-11-2008 | 12:48 PM
bww3588's Avatar
where can you buy the roll pin from? like the one from mcleod.
Old 09-11-2008 | 02:49 PM
the_merv's Avatar
Damn.. I hate when that happens..expecially when you pop a small spring out of something and it goes flying across the Garage, then lands somewhere..
Did you try Napa?
Old 09-11-2008 | 04:55 PM
Viper's Avatar
If you have an old slave lying around, the quick disconnect is held in with the same size pin....
