Iowa Fastest Cars?
#3161
So i just FIGURE i wasnt made for owning a car its to stressful, so i just get my heads and cam done guess what decided to crap out on me my tani, it wont shift into 2nd and 4th gear it will give a ball busting grind. Anyone know of a shop that does synchro's for cheap..
#3162
Location: Home town Clive,IA current town FORT BENNING GEORGIA
not yet on sub frames but soon im just cruising not getting on it much and if i do its mainly in a higher gear.... its got a new clutch already a spec +3, i took the car to cottman.... i didnt have the tools. i havent even drivin the car for 200 miles i was told on hear my synchros are either bad in 2,4,6 my hydraulics went out, or my master cylinder... that is so much bullshit then when i called them on friday when this started to happen they told me to wait till monday....
#3163
anybody ever see a LT1 optispark with the cable installed as part of the assembly? im changing the one in the camaro out since it melted the rotor lol. pulled it off and was like wtf.....so i had to order a cable for it $52 online better than the $232 GM wanted.....********
#3164
SUGAR SHACK SHOW 'N SHINE (June 27, 2009)
#3165
Thanks! I'm good without boxes, I'm not shipping any wheels, just thought it would be nice to have the boxes they came in. The car feels like an animal with skinnies on it. I want to go to the track, soon! I need that timing adjustment, so I can spray it though.
#3168
I know i can't wait! We're leaving friday at 2 p.m. sharp! haha
#3169
#3170
I would, I have a golf outing Saturday & still haven't fixed the studs on my right axle. I'm avoiding doing it, any local guys know where I should take it? I'm going to put ARPs in it, never had a problem with them on my stock axles...
#3174
im in the process of pulling it off again. the last opti was the rotor. thing was just slagged. so im going to see if this one is the same way. if it is there is something wrong in the ignition system (MSD box, or coil, hell maybe even a plug wire)
#3175
I just put mine up in the air and setup the rear suspension. making sure the rear was centered side to side and front to back/both the same on each side. Looks good and ready to go. Im thinking that I am going to try my luck tonight and head up to CFR for the midnight mania deal. The rain looks to have broken up so far and looks to maybe stay that way tonight. I will be in trouble if I have to drive the car home in the rain. Will make for a LONG LONG LONG drive home on these bald *** DR's.
#3177
haha, **** that. LOL I dont have any other rims/tires. Im broke brah! Well I didnt end up going anyhow, but decided to toss on these bad boys instead:
That is all
Figure these little gems will help me plant the rear tire and hopefully find that traction that i cant seem to pick up!
That is all
#3179
so i just replaced the 6AL box on the camaro with a new one. car fires right up everytime so far even when i let it sit and get hot. going to test drive it and see if the problem is finally solved. let me know how the settings on the QA1's go for you rodney. i need to set mine sometime too lol
#3180
yeah Dave, i got the spanner wrenches. I had them on 5 for street driving, but that didnt help plant the rear tires at all. Infact I think it made it worse. But, wont be testing it out for a minute. I did 2 dig runs last night when testing them out and then I had a knock under load. So I have to try and figure out what the hell that is. I just ripped into the valvetrain and it all was fine. No broken springs or needle bearings missing out of the rockers. Next step is to jack it up and check and make sure the tq converter bolts didnt loosen up, or the flexplate crack or something similar. If that all fails then the motor is coming out. Nothings gone right with this car latelly.
