Another Hall's deal!!!
#7282
Blake, are the 3000k really worth it for foglights? I was thinking about going with a matching set (heads and fogs) There is a bit of a cool factor with the yellow fogs, but i am thinking that its mostly a european look.
I read over on SVT performance that anything more than 6k and you are actually losing the amount of visible light being produced. Is that what you were saying earlier?
On a side note, i just found a guy that just installed the suspension that i am looking at. He has dropped 1/2 sec over his stock suspension with no other mods. I am thinking that with tires gears and suspension i may be closer to a full second off my 1/4 time.
Next season is gonna be a blast with all these faster cars in town!
#7285
Sorry, I don't care the driver, if he can launch an Evo on street tires well enough to get past me on 275 555Rs in a 2700 lbs car with good suspension, he's doing pretty good already. Not to mention I'm light enough he's not staying anywhere ahead of me for more than a few MPH.
#7287
Also, yes, that's what I was saying. MAX light output is at 4300K and it drops from there. The difference from 4300K to 6000K isn't a lot (like 8-9%) but above that it drops off quickly. Keep in mind that any HID setup is going to be 200-300% more powerful than your stock lights, so a few percent off of "best case" is still much brighter than stock. 6000K is what most people in town have I think? Nate, Ben, BB, Ricky Martin, Drew and I all have it I'm pretty sure.
#7289
i killed him and cobb on 69 that nite where he about ran me off the road...that mr is nothing...8+cars ohhh that was fram a dig....ben would not even waste the gas on him...would not even be close 14+ cars
#7292
In tank fuel system:
It's dual walbro 255 lph (with check valves) into 3/8 fuel line into aeromotive y-block into -8 AN which then upsizes to my -10 main fuel lines after the bulkhead. I haven't finished the wiring for the second pump (activated at 4 psi of boost with a hobbs switch).
#7296
That's who will probably weld mine on in the early spring!! I've got them already out in the garage along with the rest of the suspension parts I got for my winter project. How much does he normally charge to weld-in subframe connectors? PM me if you have to if you can't post it.
#7297
#7298
It's just some spare -6 AN I had laying around. The main feed is -10 to the rails -8 between the rails and then -6 back to the tank (with the -6 you see there for the in tank return to get the fuel back below the level in the tank to prevent splashing). I have a few types (Russell, Summit, Aeroquip, BMRS) but I think the in tank hose is Russell.
What do you have in mind?
#7299
the piece in the tank?
#7300
LOL. I had the -10 hose already, and the uber fittings on the intank is a combination of stuff I had, and me clicking the wrong button when I ordered the fittings. I spent WAY more than I wanted to on intank bits, but hey, next system I do (Beast) we'll be able to do it a LOT cheaper.
