Another Hall's deal!!!
Hello LS1 techies
I have a guy helping me finish up my Nova with an LQ9 in it. The thermastat is not opening. The car has been running enough for the gauge to read 210* 3-4 times. I have all truck accessories except the water pump which is 98-02 Camaro WP. We have used 2 new thermastats.
1. Does the Camaro WP flow a different direction?
2. Just to make sure, does the water flow out the upper hose into the radiator & back in from the lower hose?
3. Any other possibilities?
Thanks
Thanks
2) Correct
3) What temp t-stat do you have? Throw the t-stat in a pot of boiling water and watch it to confirm it either is or isn't opening. You can get fancy if you want and put a candy thermometer in the water with the t-stat and let it come up to temp and see what temp it starts opening at. What are the details on your radiator and cooling fan?
1) They flow the same direction
2) Correct
2) Correct
I prefer tinypic.com then you just copy the [IMG] file and paste it in a thread. You can also use photobucket. If you use tinypic, you may need to shrink the size a little if you post on this forum because they can be pretty big.
Are you a sponser? Can you advertise here legally????
lol Just razzin' ya Joe. Where have you been?
Anybody on here work with or have connections to a good concrete contractor? Had to pull my vinyl deck out and found that the idiots laid the framing on the ground and it proceeded to collect 4 inches of water not to mention soaking the lumbar. NEEDLESS to say it's not going back in.
Anyone interested in Brock vinyl decking with channel clips,screws, and steel insert vinyl overlay railings hit me up, I will make you a good deal on it.
Will cover a 14'x20' area.
Thanks D.
Color of decking is light tan and railing is white.
Thanks D.
LS1Tech Sponsor
Congratulations Rob, the cover of GM High-Tech looks awesome! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Thanks D.
Thanks D.
http://www.rufushsmith.com
Call Dan Roy at Rufus H Smith concrete. He does the majority of our concrete work. Tell him I sent you
Thanks, I will give him a call.
Still doing the car thing
Here's my new project that is close to being finished. Later this summer ill have the nitrous on it.
Heres a video of its first start with an exhaust on it. But still alot of work to be done
http://static.photobucket.com/player...9-10-47-36.mp4
