Need ls1 balancer install tool in Indianapolis area asap.
Does anyone in Indianapolis have ls1 balancer install tool I can rent or buy from them. I need one asap. Its all I need to get new motor finished and car back on the road.
Thanks
Thanks
Me and a few buddies changed a crank pulley out and it was a PITA locating the tool. Good Luck!
BTW We ended up using a piece of wood to cover the crank pulley and gently tapped on it with a hammer until it got started enough to put the bolt in and tightened it up. Good Luck Either way man!
James
James
I went today and bought the 16 mm all thread, nuts, and washers to make my own. Noone had it on Saturday when I started looking. I had to go to specialty bolt place to get the all thread. If anyone else needs one I have enough to make two more. I will be keeping one for myself. If someone wants one I will sell parts for $20 which includes 3 nuts, foot of all thread, and a washer.
Depends on the balencer... If I am not mistaken dont some have rubber inserts that can be damaged... I put mine in with a longer threaded bolt and an impact. Since I didnt want to take the chance of anything getting F'd up, I took it inside for the night, and let the garage cool off to outside temp... in Jan. Went on easy as pie.
I tried the oven trick first thing. That was how I did the last one and it slid right on. This new SLP was a no go in the oven. Its now on and all I need now is plugs and the new 403 will ready to fire.
people do more damage trying to use long bolt vs. heating the balancer, its an interference fit.
if your properly heat the hub of the balancer you will not affect the rubber.
Should you be concerned with deforming the rubber use a propane torch or oven, it will take twice as long as acetylene.
