(USAF) question about awards and decorations
I always have followed what the vmpf shows. I'm not sure if it's right. I asked a friend and he says it's not always right and that you can get in big trouble if you don't have em right. So how are you supposed to know what ribbons you should have?
Take the VMPF rip to your local Awards and Decs section at MPF, and ask them to verify. I know for a fact that VMPF is not always correct, especially on devices. Perfect example, my VMPF shows that I should have 4 devices on my good conduct ribbon, but I have only been in 15 years...Good conduct was awarded every 4 years until they got rid of it.
Jack
Jack
Jack
Jack
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Well i have one meritorious unit award for sure...i've been in under 3 years and it's telling me i got 2 bronze oak leaves..that's not even possible right?
I'm not sure how it works cuz no one has explained it to me, but to me, the medal counts as one and each oak leaf is 1, which equals 3 awards..and a meritorious unit award is only every year right? Or do i just need to do some research?
And while it's not always accurate, I don't think you can get in trouble for following it (unless of course its a big time award that is protected by the stolen valor act)
My devices still aren't right after showing them all of my awards rips, so just remember what you've earned, and keep all the rips, especially if you get a short tour from the desert. Also, keep all your orders and travel vouchers.
OUA are easy as crap to get. They are basically awarded to any base/squadron which passes an inspection above a SAT or has a direct impact on the missions at hand. In my 3 years at 723AMS at Ramstein, I got 4 OUA's because of what the mission was there.
MUA's are VERY hard to come by and there are probably only a handful of people who have more than 1, and they are usually SOF people. If you were in the 332AEW or Club Med, you got one 2 years ago....those were the last two to be given though. And before that, was like 2002.
GUA's are impossible unless your JPerran or one of those AFSC's. I have never seen anyone outside of Cops or SOF have them
My guess, is you were supposed to have the OUA and whoever put it in the system fucked it up and clicked the wrong ribbon. I can tell you right now, unless your a TSgt or above and you walk around with 2 oak leafs on that ribbon you will get called out fast.
You also don't have to listen to what the vMPF site shows for your decoration because 90% of them are wrong. It doesn't self update when you are awarded anything and has to be done manually by a CS rep in the MPF itself. The only ones that are automatic are your real decorations (e.g. medals). Your "been there" ribbons have to be manually added. PME ones are put in by the PME instructors after graduation. Automatic ones to the entire branch (e.g. GWOT) are automatic. The rest like marksmanship, GWOTE, Short/Long Tour, Unit Awards, etc have to be put in manually by proving you have received them.
Well this is taken from Wikipedia...
The MUA is awarded to Air Force units for exceptionally meritorious conduct in the performance of outstanding achievement or service in direct support of combat operations for at least 90 continuous days during the period of military operations against an armed enemy of the United States on or after September 11, 2001.
I'll ask someone higher up around here I guess.
The first was in summer of '04 during my deployment to Kir Kuk, Iraq, and the second was in summer 2006 during my deployment to Baghdad, Iraq. Both times were under the 332 AEW. I just got done with my third deployment, which to Tallil, Iraq, attached under the 332 AEG, so I'm keeping my eyes open for another one.
I've got a ton of Outstanding Unit awards, they give them out like candy. As far as the MUA's go, right place at the right time I guess..
Your orderly room would know if they have gotten Meritorious Unit the past three years...since that is a pretty big deal. And you usually have to get a Outstanding Unit to get a meritorious.
Or try calling your local MPF, the awards and decs section, and Im sure they could review your records and fix what needs to be. Cause I highly doubt you got Meritorious the last 3 years.
I just looked at mine and it's messed up in a few places. I don't have my Iraq Campaign Metal, instead I have just a normal Expeditionary Metal. That and my MUA's aren't on there, but I still have the 2 notices that were sent out when we were awarded them. I'll have to bring my Travel Vouchers from my first 2 tours to them guys in MPF and have it straightened out.
