How not to pull a motor...
#122
OP seems to be taking the flames well and it's just some good-natured bashing, I see no reason to close it.
OP, what year/model is your Mustang and what do you have done to it?
#123
I pulled an LT1 out of a buddys camaro like this nothing wrong with that, I gota admit I was a lil shocked at first when I saw how we where gona do it..... I don't see how you can take it through the top without a bracket that bolts to the intake
I would feel safer with the ramps in the rear vs. jackstands
#124
My car is a 98 Cobra it has a march fluid dampner, electric water pump, k/n filter, 4.10's with moser 31 splines, and a little shot of giggle gas
Oh and you wouldn't happen to know why it still shows I have 0 posts do you? Thanks
#126
Thanks, Like I said earlier to someone who has never seen a motor pulled that way it looked unstable to me but then i was notified that it is common on the f-bodies so I understand.
#130
especially if everything is getting replaced( k-member, whole front suspension, engine etc, transmision) just worked out to my advantage.
#131
With a lift and a friend the k-member can be dropped in 45 minutes, if you've done it before.
I've done it in my driveway in just over an hour.
Pull the engine out from the top that quick
#137
Administrator
...and for that matter, you're a "****** newb" too.
