Coyotah vs ls
#181
7 Second Club
I never said it was but since you brought it up.....
The fastest LS in the world is all billet and still slower than numerous 2JZ and mod motors.
Ps. At least 2 of the mod motors were NOT billet block and the LS still hasn’t beat them. Lol
#182
Well my disgraceful cars aren't gettin drug by 12sec cars like yours. As a matter of fact both seem to do stuff you and your buddies have a hard time dealing with.
So you know how much maintenance my clutch requires.....because you have one? Or because moufy and you think you know?
Back on topic ........2 cyl worth of power from this test would be enough to break your block.
#183
Obviously not dipshit, you don’t race. You live your race life through YouTube and Fill.
only kills you have are the OEM motor, the LS6 and the LS7....yes, you killed 3 of your own motors. Congrats, you played yourself.
#184
These were built to be streer engines in a 15k budget......the coyotah got body slammed.
Yea man ....phil and i help each other. When one isn't kicking you in the ***** with our results the other is. It's great.
#185
#187
The amount of effort and time invested is what should matter, regardless if it's bolt on **** with FP'd trans and homemade holes in every part with a hockey puck clutch that requires as much maintenance as a boat, or off the shelf heads and cam with used parts surrounding an SBE from 1985. For the time/effort, your cars are disgraceful.
Your *** is chapped because I'm running a motor designed a billion years ago and am running faster than you said I would. Ouch. Humble pie tastes like ****, huh? Apparently H/C is the way to go for reliability because you've fucked up 2 Camaro motors now and 1 termi motor, which all have stock heads and cam. How bad do you suck at cars?
I bent 2 valves in my ls6 is the only ls engine issue i created. Drove it home like that. Do you think the coyotah in this test was able to drive home?
Not sure what my camaro or mustang that's both faster than your turd by ALOT has to do with the coyotah getting it's *** wire out in this comparison tho.......but you seem hurt about it. And i think it's funny. Cry more please.
#189
"It is dry-decked. No water passes from the block to the heads through the decks. Billet plugs for the water passages in both block and head then o-ringed and copper gaskets. Water passage is via external hoses. Absolutely amazing what John has done with these engines."
So who GAF about "factory" anything when that type of shyt need to be done to it? Who GAF about billet blocks? Just like rocker arms being boltons for old 302 we come full circle to not being for ls, and when aftermarket was welcome for 302 now its not for ls... LOL at the flip floppin. MOve the goal post or change the rules right lol?
#192
I just dont get it, first they think cyl sealing magic from way back when like the block and heads were welded together from the factory or some shyt, and then think 4 valve magic when boost is applied. Laws of physicas dont change CUZ 4 VALVE OR CUZ FORD lmao. They also said in that thread they were already using a billet crank. From what I remeber they were dry decking the block in 09 possibly before. No one actaully fully knows from reading the little comments and articles from Mihovetz what actually was going on, he is a racer his product is his own secret and as dumb as these fanbois ************* are on here he surely dumbed any info down so they might be able to comprehend it without drawing a 20 page picture book.
#194
Considering the 5.3 sbe with a factory head is at 7.1 and I dont think the block is filled, I dont see how a built bottom with a filled and oringed block and a decent head couldnt get into the low 6 territory in a Pro Mod chassis ohh and 2 turbos and 20lbs more boost. The problem is what is the incentive? To run a number for no specific class?
#196
Not sure why this is a Ford vs GM thing. The fact that US car manufacturers can compete with companies such as Ferrari or Porche with making good power and reliably for a less money is something to be proud of.
I'd actually like to see the Mopar motors get involved with this also.
#198
And again.....why would you put the same size blower on a 5.0 as a 7.0? Does the coyote need more boost to compete?
#199
Neither made full power and the coyote got spun hard enough for catastrophic failure. The ls woulda lived FOREVER at the power level the coyotah failed.
#200
