Coyotah vs ls
85 mph H/C/I 6.0
Can't even tell when a transmission starts in 2nd
Thinks 6,000 lb trucks should get the same mileage as Vettes
Thought Tennessee had more all time wins than Nebraska
There's no end to your stupidity
You just admitted that you can't tell what gear you're in without looking at the shifter lmao. And What happened to Alabama in the Championship game? You always ride their dicks because Tennessee SUCKS. And will only get worse, while Nebraska is heading back to the 90s dominance. 85 mph lmaoooooo. Your brain should be studied in a laboratory. So two 427 ls motors with same heads & intake. How can someone tell the difference of the two. Someone gone bite? Lol.
True but you can just run E85... it is very effective at pulling the heat out of the cylinder. It still doesn't cool the intake charge on a DI system but that isn't really where the issue is. I have yet to hear of a SBE LT1 failure on E85. Several on 93...too much compression imo for the tight ring gaps. Very little room for error in the tune above 7psi. Meth is a must if not running E.
I can't believe you've been on ls1tech this many years and have no clue about ls stuff. You gotta be a complete idiot.
That's how stupid you really are. Again, your brain should be studied in a laboratory.
