Coyotah vs ls
Maybe take a dip into the technical sections every once in awhile instead of getting ALL your information from what others regurgitate in this section.
Dweeb.
All because the boosted 5br0 got absolutely MURDERED on that dyno.
Nice deflection, ******* lol. Snail95, your tears are music to my ears lmao! I guess all those crashes of yours killed more brain cells than i initially thought.
As well as Doug and Hams.
Dweeb.
I would eviscerate your slow piles of ****, just like Scott Frost did to Peyton Manning in the 97 National Championship game. I own you, bitchtits. True but you can just run E85... it is very effective at pulling the heat out of the cylinder. It still doesn't cool the intake charge on a DI system but that isn't really where the issue is. I have yet to hear of a SBE LT1 failure on E85. Several on 93...too much compression imo for the tight ring gaps. Very little room for error in the tune above 7psi. Meth is a must if not running E.
My 2002 came with LS6 block and LS6 intake. It had 241 heads and the 6.0 cam. Pretty common...some still had LS1 blocks as this was a transition year. Just depends on the build date I assume. It's nothing special really...the LS1 block was actually a little stronger.
