Coyotah vs ls
I agree that NA to NA and even nitrous to nitrous......cubes are king.
When FI (terbo or blower) is used, it really has very little to do with cubes, either the motors can take the CFM delivered or it can't.
Hence....... 2JZ and Mod Motor has been faster in the 1/4 than any LS so far, if it was cube dependent then LS would squish both of those platforms without any problems.
Why don't you sell your gm stuff? You're clearly a closet furd dude just like your a closet ******. You're not a closet dumbass tho.....that's out for erryone to see.
Lets get this straight. The coyote wasn't even close....like not at all. It failed at a point that even a sbe 4.8 woulda survived. Even if the coyote woulda got to 30psi of boost it was still gonna be out powered bigtime.
Your *** is chapped because I'm running a motor designed a billion years ago and am running faster than you said I would. Ouch. Humble pie tastes like ****, huh?
Apparently H/C is the way to go for reliability because you've fucked up 2 Camaro motors now and 1 termi motor, which all have stock heads and cam. How bad do you suck at cars?
