Problem with Sean at Eastside "SPRSPT"
Thanks
George
above notice the deck thickness difference eastside left stock on right
above notice the head bolt mount height difference eastside left stock on right
the above phote is the eastside head on left and stock 243 on right notice the difference in height
above is the top view of the heads notice the eastside head on the left is lower then the right stock 243 on the right
above is 2 untouch 243 heads side by side notice the height is the same
above is 2 stock 243 side by side
above is 2 stock 243 heads note deck thickness
dowel hole of eastside head
dowel hole of 243 stock head
above notice the deck thickness difference stock on top eastside on bottom
above notice the deck difference eastside on bottom stock on top
above same bolt hole both heads eastside left stock on right see how much is cut off
George post all you want we are done wasting time with this issue....You bought used heads and didn't check/confirm your clearences......
clearence was checked on cyl# 1 problem is your heads did not match and # 8 hit
