Couple questions.
I've had my car for a lil over a month and decided to put the rear up on ramps to try and find the cause of a noise I keep hearing, I found it,I think? muffler making noise over bumps and during take off and stopping, the rubber hanger things are looking a little stretched, anyways on to the questions.
question 1. is the drivers side of the Y pipe supposed to be flat? it's about 1 1/2 inches thick
question 2. whats the ladder bar looking thing that runs along side the driveshaft?
Thanks in advance for your replies and suggestions if any given.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
so I would imagine the replacement of that pipe would give a little wake-up to things.
so i'm thinking my first few mods will be exhaust.
Thanks again.
Not sure what exhaust you have. I have SLP loudmouth, and I had to adjust it because I heard noises back there too. The pipe was rubbing around the axle area. You might want to check that area out.
I think the problem is the rubber hanger on the drivers side it looks a little stretched and tatterd so when I do my exhaust I'll replace them then unless the sound drives me bonkers before then.
