98-99 ls1 problems???
Old Nov 6, 2008 | 11:18 AM
mastercoryd's Avatar
Default 98-99 ls1 problems???
Hey guys, im looking to get an ls1 f body i've been doing lots of research on them and love them but I think the only year I can afford is like a 98or 99 cuz im picky and only want an m6. I was talking to one of my dads freinds and he told me to get a 2000 - up because in 98 and 99 the first batches of the ls1's werent as strong and had some bugs that needed to be fixed and they werent perfected until 2000, is this true or would I be fine with a 98. Im looking for a car with about like 90k too if that helps, thanks alot - cory d
Old Nov 6, 2008 | 06:49 PM
DCsLS1's Avatar
id try to get an 01 or 02 they have the ls6 manifold etc. check out the differences here http://www.smokemup.com/tech/ls1.php
Old Nov 6, 2008 | 06:55 PM
SSmokin99's Avatar
I think this is completely untrue. I've had my '99 SS for 5 1/2 years and I used to daily drive it. I've NEVER had a problem with my car. It's still running like the day I first got it.
Old Nov 6, 2008 | 07:08 PM
DCsLS1's Avatar
im not saying that there is anything wrong with 98 or 99 im just saying the 01 or 02 has the ls6 stuff
Old Nov 6, 2008 | 07:10 PM
SSmokin99's Avatar
I wasn't referring to you. I was replying to the original post. IF I had to do it again I would get an '01-'02.
Old Nov 6, 2008 | 07:11 PM
bad2dbone's Avatar
i actually heard n been told and seen myself alot of the 99's run hard as hell
Old Nov 6, 2008 | 07:28 PM
twitchtwice's Avatar
it doesnt really matter. the 98-00 engines have a diff intake, but a slightly bigger cam, and the 01-02 have the smaller cam with the better intake. i hear it really isnt that much of a difference stock for stock.
your going to mod the car anyways so get whatever you want. it doesnt make a difference.
Old Nov 6, 2008 | 08:11 PM
samson_420's Avatar
Just get anything from 98 and up. It just depends on the shape of the car it self and not the year.
Old Nov 6, 2008 | 08:16 PM
ae13291's Avatar
only 97-98 LS1 engines had some issues because those were the first years of development. the 99-up are the ones u should be looking for.
Old Nov 6, 2008 | 08:29 PM
S8ER95Z's Avatar
I don't think you can go wrong with a pre 01 LS1 car...but my 01 seems to be strong as hell (94K on the clock and going)... the LS6 clutch is a big plus too... I'm still on the original (but I don't think for much longer)
Old Nov 7, 2008 | 10:15 AM
thanks guys, i was afraid of getting a 98 ls1 now im not thanks alot
Old Nov 7, 2008 | 10:23 AM
72 Z-28's Avatar
I have a 98 and I rag the **** out of it on a daily basis and have had no problems yet. Although it will need a rear soon but thats not the engine. Just my 2 cents
Old Nov 7, 2008 | 11:07 AM
406malibu's Avatar
the only problem with 98's is the fact that they are harder to find a tuner for. aside from that they have different heads, and a few other small differences, but in no way are they less reliable.
Old Nov 7, 2008 | 01:19 PM
SOMbitch's Avatar
01-02's have better rod bolts but that didn't deter me from getting my 98.
Old Nov 7, 2008 | 01:41 PM
AgentLS1Z's Avatar
I daily drive and rag on my '98 Z and have no problems. My car is an A4 and is still plenty of fun. It's very convenient to spin the tires with. I don't have to brake stall to spin them.
Old Nov 7, 2008 | 09:51 PM
the_merv's Avatar
Veteran: Air Force
Valve Covers on a '98 are a pain in the *** to remove.
If you get aftermarket Heads and you have a stock '98, you will have to get the Center Bolt Valve Covers, and Coil Brackets.
Old Nov 7, 2008 | 11:27 PM
SOMbitch's Avatar
Valve covers were $50 on here and I don't remember what the coil mounting kit fom SDCP was but it was nominal. It's no biggie I can tell you that.
Old Nov 8, 2008 | 10:53 AM
theguyulove2hate's Avatar
i have been doing a lot of looking about and reading, seeing as how im getting ready build a new motor. The 98 and 99 are just as good as the 00-04 LS1. They made changes in late 2000 including the rod bolts, heads, cam, intake. Gm started putting the 241 heads on which is a much better flowing head, but the detuned it with the cam. In 01 they started putting the ls6 intake on and they put much stronger rod bolts in. Thats it other than a few minor changes such as egr and this and that.
Now if your looking for a solid block to build a motor get a 99 block. After 98 they redesigned the water jacks so the block cools better, but they changed that again in the 2000 model. (I dont know why i work for chevy the change **** all the time when it is fine in the first place).
Old Nov 8, 2008 | 11:13 AM
blk/slvr02ss's Avatar
I had a 98Z-28 a4 w/ a lid & off road y-pipe and ran 13.19 @ 106 on bald nittos.
Old Nov 9, 2008 | 09:46 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
This is NOT true. You'd be fine with a '98.
I've had a '98, '99, '00, and '02 LS1. The '98 has been the best built so far. I'd buy another '98 in a heartbeat.
