Bogging around 2,500 rpms
hey guys i just noticed this week that at part throttle my car bogs around 2,500 rpms but doesn't bog at all when at WOT. it doesn't throw a SES light either. if i give it part throttle gas from a stop, from 1,000 rpms to about 23-2400 rpms the car feels fine, pulls strong but as soon as it hits 2500 rpms and past it bogs alittle and feels like i lost some power. what do you guys think is going on? LMK
thanks, toua
thanks, toua
Well i may not be right but it could be a clogged CAT.. my buddy was having a similar problem with his Z28 and it was becuase the cat he had was old and clogged up.CAts are like nething else they get old and come apart inside and restrict flow..
it can't be the cats because i don't have them, i found out that it was my maf. it went bad, i changed maf's with my brother's z28 and my car ran like 100 times better. how could my maf go bad without throwing a SES light?
Why are you switching to SD? It more costs more, and is alot harder to tune. I dont see a mods list, so i dont know, but if your pretty much stock id keep it the way it is. Whoever is selling you on SD may have left some stuff out.
I am in the process (the last 2 days) of switching over... thats why i ask. And just so you know we have spent probably 3-4 hours easy of straight data logging and adjusting stuff to make the tune work well... and thats with data from a similar car! Were still no where NEAR done. So unless you know someone whos going to help you do the tune and you actually NEED to switch over, i wouldnt. I only did because of the boosted application.
Probably because it was just that one place. Not completely dead. And to be honest it probably just needs a good cleaning. If it was completely dead your car would be sluggish across the board, since its adjusts the fuel according to the air flow. If it reads no air flow, it would rely on the map alone... and be very sluggish.
