EGR and AIR delete question
Old Nov 23, 2008 | 04:14 PM
user 648967286742's Avatar
Question EGR and AIR delete question
ive have a set of LT pacesetter and looking to run an EGR and AIR delete to clean up the cluster in the engine bay. i was looking for instructions on how to do this, what i need, and how it will make effect my car and how it runs. i also know i will need to have my ses light tuned out. can any shop do this or what. any input will be great. thanks.
Old Nov 23, 2008 | 04:25 PM
CanII's Avatar
Basiclly you will need to install the block off plates on the headers. You will have to unclip the rubber hose that hooks up both headers from the rear of the intake manifold, held on by a plastic c clip. you will also either have to disconnect the air pump or have a tuner shut it off for you. Also the light in your dash wont come off till a tuner comes in and deletes all the smog related pieces in the computer.
Old Jan 15, 2009 | 08:17 PM
chevy0128's Avatar
how much does it cost for someone to tune out the light on the dash
Old Jan 15, 2009 | 08:19 PM
nemss1's Avatar
speedinc and texasautocraft.com sell the blockoff plates
Old Jan 16, 2009 | 09:06 AM
CodeRed2000SS's Avatar
you can make the plates with a 1/8 inch peice of metal. drill two holes in each end for the bolts. your ses light will light up if it has not already due to the headers.
Old Jan 16, 2009 | 09:10 AM
therealcreeper's Avatar
TTP which is right by me charges $70
Old Jan 16, 2009 | 01:49 PM
trey1010's Avatar
So you need to block off the header spot for the egr and air but will you also need to block off where it went into the back of the intake?
Old Jan 16, 2009 | 02:01 PM
nemss1's Avatar
plate with expansion plug
Old Jan 18, 2009 | 01:12 PM
where do i get the materials for the back of the intake at?
Old Jan 18, 2009 | 02:14 PM
nemss1's Avatar
vacuum plug for the nipple at the back of the intake
Old Jan 18, 2009 | 05:05 PM
2000badbird's Avatar
if its an 98-00 intake get a 1 3/8 freeze plug for the intake manifold where the egr commes into the top of the intake make a block off plate for the air and its simple and easy and get a vaccum cap for where the air line is on the back of the intake i did mine and it only cost me $1.50
Old Jan 18, 2009 | 07:42 PM
where exactly is this AIR line on the back of the intake? is it near/under the diverter valve looking thing?
and i just did headers on my car and left all of the air stuff on except where it goes into the manifolds so right now it's just pumping air out of the hoses on both sides of the engine. does this still cause a vacuum leak?
Old Jan 18, 2009 | 08:22 PM
nemss1's Avatar
it is on the very back of the intake manifold in the center. have to reach back there to get to it which is kinda a bitch
may cause a vacuum leak since the air injection also uses vacuum from the back of the intake. not entirely sure. because the air coming from those hoses is coming frm the air pump
Old Jan 18, 2009 | 09:04 PM
okkk.
i didn't feel like pulling the whole pump and everything out so i just left in for now. if it's not causing a leak i may just leave it for a while. otherwise it'll come out tomorrow hahah.
Old Jan 18, 2009 | 09:08 PM
nemss1's Avatar
just pull it man. its not that hard. 4 bolts and the lines
Old Jan 18, 2009 | 09:11 PM
jboice06's Avatar
im not so sure of the back of the intake there talking about ive got a 99 and never plugged anything at the back of my intake, my buddy made me some block off plates out of 1/4 aluminum and i just ripped everything off and put the good ole freezeplug in and drove it to the tuners to get it deleted and today i took the heavy pump out ive heard and witnessed air pumps making a knocking noise after egr delete if you dont tune it out
Old Jan 19, 2009 | 02:07 AM
nemss1's Avatar
yes there is a nipple on the back of the intake that should be plugged after removing the AIR injection. take the pump comepletely out if u are worried about a knocking noise. never heard of that though
Old Jan 19, 2009 | 07:37 AM
7998's Avatar
I have '98 and don't remember plugging anything on the back of the intake, Damn now I got to go look for it.
Old Jan 19, 2009 | 10:37 AM
WhiteFormula98's Avatar
One of the first things i did to my car was removing that clutter...sh*t was annoying
Old Jan 19, 2009 | 02:14 PM
D_Rock's Avatar
I have a 02 WS6 if I remove my air/egr then will it affect my air lid since there is a hose going into the side of it. Could I delete my air and then plug the hole in my air lid? would I have any problems. I really am wanting to delete this and clean up the engine bay some. Can someone please help?
